New FrSkyX protocol
- Alexandro
24 Apr 2016 15:01 #47093
by Alexandro
Replied by Alexandro on topic New FrSkyX protocol
Test Ver.255
System lock up at boot and Beeps
greetings Alex
Test Ver.255
greetings Alex
25 Apr 2016 01:25 #47129
My bad - built with the wrong compiler. New
test version here
. I also removed the static qualifier so this should be equivalent to the 739 build. I verified this build is the same as produced by building with the docker image and will continue to do so until I get this merged to github.
Thanks for the testing!
- Alexandro
25 Apr 2016 06:29 #47142
by Alexandro
Test Ver. 187
Bind works on Channel Number set greater 8
PWM out 1-8 does not work , only working on Channel Number set to 8 or lower
greetings Alex
Test Ver. 187
greetings Alex
- darker44
25 Apr 2016 07:33 #47143
by darker44
Replied by darker44 on topic New FrSkyX protocol
Test report : version '187'. With x4r-sb , sp-r-f3 , devo 7e .
I've got bind, solid green light, tested 12 channels first, nothing moves in cleanflight,
then changed to 8 channels - works but pitch and roll are changed.
when adding more channels e.g.9 - ch 1 stops working. 10-ch2 , 11-ch3 , 12-ch4
Waiting for the next version to test
26 Apr 2016 02:23 #47202
ouch...let's tack downwind a little bit. I've moved to github and building with PB's docker image.
The frskyx bitbucket 739 changes are build dfcf1e0 in github. The frskyx code is the same as the bitbucket 739 build, but also the latest nightly changes are included. Fingers crossed this works on the 7e - not making any more predictions :/ Test version here .
If that works I've also made a second test version with some additional changes that should not affect the 7e. Version 8e903ef .
Thanks for the testing and patience!
- Alexandro
26 Apr 2016 06:40 #47214
by Alexandro
Test Ver. dfc
Bind : ok
-> green light on RX does Flicker, no Servo moving
-> Channel Number 8 and 12 , all same. No Movement and Green Light Flicker
Test Ver. 8a9
No Boot, only Beep and Clear Screen with Backlight on.
greetings Alex
Test Ver. dfc
Bind : ok
Test Ver. 8a9
greetings Alex
- darker44
26 Apr 2016 10:51 #47224
by darker44
TEST. For me both versions : 'dfc' and '8e9'
After the flash Devo keeps restarting, there is no logo on the screen, just sound and blinking. There is a bootloop.
Reverted back to 739 and works fine. @hexfet , can you tell me if I can fly with 739 firmware now ? I just finished my new build and wanted to use x4r receiver.
What is missing in the firmware ?
Thanks for your work!
26 Apr 2016 18:22 #47249
I am definitely not understanding something about the 7e build. Compared assembly listings for both dfc and 8e9 and the generated code is identical except for the version number. That's consistent with darker44's report but Alex got different behavior.
Let's do a sanity check. I've created a protocol_frskyx3 test build 8e9 with versions for 10, 6, 8, and 12. Please test if you can to make sure the move to github/docker was successful.
I'd do a full-power range check before any flying.
It's not missing any features. Using Deviation is always subject to the warning on the front page of www.devationtx.com . That said, if everything looks fine in cleanflight, if it was me, and my build was a CF quad that won't get damaged much, I'd be comfortable hover testing at a few feet - over soft grassdarker44 wrote: Reverted back to 739 and works fine. @hexfet , can you tell me if I can fly with 739 firmware now ?
- Arakon
26 Apr 2016 18:24 - 26 Apr 2016 18:25 #47250
by Arakon
Replied by Arakon on topic New FrSkyX protocol
I haven't kept up with these new versions, but I can tell you that the old one I am still using worked great at range, doing acrobatics, etc.. zero issues, RSSI also working. So my guess is that if you have a working version (for the main protocol) now, it'll be fine for actual flight.
Last edit: 26 Apr 2016 18:25 by Arakon.
- darker44
26 Apr 2016 19:16 #47253
by darker44
Hey Arakon, can you tell me what version are you using ?
Thanks hexfet anyway, so I'm waiting for people to test other DEVO receivers now, and I'm always happy to help with 7e testing.
I will test flying with working version also.
Arakon wrote: I haven't kept up with these new versions, but I can tell you that the old one I am still using worked great at range, doing acrobatics, etc.. zero issues, RSSI also working. So my guess is that if you have a working version (for the main protocol) now, it'll be fine for actual flight.
- Arakon
26 Apr 2016 19:21 - 26 Apr 2016 19:30 #47255
by Arakon
I'm using 15e8960, that was one of the releases just before work on the telemetry stuff began, I think. I unfortunately don't have the file anymore, which is why I am reluctant right now to test any other versions.
I'm using it with an X4R-SB and an XSR receiver, btw.
Edit: Actually found the dfu file and put together the file system stuff needed I think.. I've attached it if you want to try.
This is from early march, though.. keep that in mind.
Last edit: 26 Apr 2016 19:30 by Arakon.
- TomPeer
26 Apr 2016 20:17 #47258
by TomPeer
Replied by TomPeer on topic New FrSkyX protocol
I just tested frskyx3 with devo 10 and devo 8s.
all 12 channels work fine. i got rssi and voltage to rx. Also used a lipo sensor (smart port) gives total voltage and voltage of 2 cells, Plus an extra box with unknown voltage witch gives strange readings. (i guess a small glitch)
Tom
Tom
- TomPeer
26 Apr 2016 20:49 #47260
by TomPeer
i also tested the dfc and 8e9 on the 7e.
with both versions: white screen beeeeeep and power of. (by it self)
Tom
Tom
26 Apr 2016 21:59 #47271
Can you describe the location of the extra box, or post a screenshot?
Thanks for testing. Glad it's workingTomPeer wrote: I just tested frskyx3 with devo 10 and devo 8s.
Tom
- TomPeer
26 Apr 2016 22:23 #47274
That is the minimum cell voltage. The black background means no lower value has been reported in the previous five seconds.
If you saw a value of 0.77 it implies a spurious low value might be reported, maybe as things are powering up. Might need to update the code to reject values less than 2V or so.
- TomPeer
26 Apr 2016 22:27 #47275
by TomPeer
thanks, good to know. Than all seems to work fine.
Good work.
Good work.
- Alexandro
27 Apr 2016 08:10 #47294
by Alexandro
Test Ver. 8e9 on Devo 8s
Rssi ok
Volt1 ok
PWM 1-8 ok
looks good
doing deep Test later
greetings Alex
Rssi ok
Volt1 ok
PWM 1-8 ok
looks good
greetings Alex
29 Apr 2016 00:43 #47396
The protocol_frskyx3 test build is updated with version 61e, including a build for the 7e. Might have found the 7e issue...
The min cell is now updated by scanning all the cell values whenever cell telemetry is received. Might see 0 flash up until all cells have been reported at least once through telemetry.
- Alexandro
29 Apr 2016 06:52 #47404
by Alexandro
Test Ver. 61e on Devo 7e
Beeps and does not Boot
greetings Alex
greetings Alex
Time to create page: 0.416 seconds
- New FrSkyX protocol
