Eachine E010 inductrix clone data captures
28 Aug 2016 18:48 #53214 by goebish
Replied by goebish on topic Eachine E010 inductrix clone data captures
Cool, next step will be to try to crack txid / rf channel relationship, or at least have captures from at least 5-6 transmitters so we can race without interferences ;)
28 Aug 2016 18:52 #53215 by HappyHarry
Replied by HappyHarry on topic Eachine E010 inductrix clone data captures
yeah that will definitely be needed, as a few guys at the club are on their way home to order one right now now after seeing mine fly with my 7e today lol, i'll see if i can borrow/claim their stock tx's to get some more id's for you
28 Aug 2016 19:47 #53216 by rasqba
Replied by rasqba on topic Eachine E010 inductrix clone data captures
goebish wrote: Cool, next step will be to try to crack txid / rf channel relationship, or at least have captures from at least 5-6 transmitters so we can race without interferences ;)
Let's hope it's not as difficult as the DSMX "enigma" haha :D Good luck and thanks
29 Aug 2016 03:16 #53229 by bigicedog
Replied by bigicedog on topic Eachine E010 inductrix clone data captures
noob question. will i need a module for this,or can i fly it straight with devation?
29 Aug 2016 03:29 #53230 by goebish
Requires nrf24l01 module.
29 Aug 2016 17:48 - 29 Aug 2016 17:57 #53243 by SeByDocKy
Replied by SeByDocKy on topic Eachine E010 inductrix clone data captures
There is a specific ID to give ? coz sometimes I can't bind ...it or have slow responses .... but maybe it's coming from nRF24L01..... I will check with another radio
EDIT: it's my NRF24L01 module ... sometimes not working :( a small short somewhere for this radio
Last edit: 29 Aug 2016 17:57 by SeByDocKy.
29 Aug 2016 17:51 - 29 Aug 2016 17:51 #53244 by goebish
Given ID doesn't care, there's only 1 hardcoded in the code.
A few people tried it already, it seems it's working fine ...
Can you make a capture of your stock transmitter to help understand txid please ? (just bind sequence)
Last edit: 29 Aug 2016 17:51 by goebish.
29 Aug 2016 17:58 #53245 by SeByDocKy
goebish wrote: Can you make a capture of your stock transmitter to help understand txid please ? (just bind sequence)
I will .... Classic XN297 pinout ?
29 Aug 2016 17:58 #53246 by goebish
almost ... it's a 3 wire spi xn297l (8 pin), but just capture as usual, csn + clk + data
30 Aug 2016 20:59 #53300 by parriehunter
Replied by parriehunter on topic Eachine E010 inductrix clone data captures
goebish wrote: Ok, looks like it's running at 250kbps instead of 1Mbps
new build:
Devo 7e
crossing fingers :P
Hi I have installed this build but cannot get it to bind, does anyone have a model set up that I could try?
Thanks Guys and Girls
DEVO 7E
Hubsan X4
30 Aug 2016 21:03 #53301 by goebish
Are you sure your nrf24 module is working ?
(tested with another protocol ?)
30 Aug 2016 21:11 #53303 by parriehunter
Yea I worked it out, in the protocol_opts did nto work out had to set Format=E010.
Done that and it has bound.
I had a look at some code of yours at github and worked it.
You are an absolute genius. Can't wait till lunch time and take this for a fly.
Thanks again
DEVO 7E
Hubsan X4
30 Aug 2016 21:15 #53304 by HappyHarry
parriehunter wrote: You are an absolute genius.
+1
03 Sep 2016 23:36 #53456 by chaotix
Replied by chaotix on topic Eachine E010 inductrix clone data captures
Hey guys, this is working great. I only have one rate at the moment and it feel like it needs to be higher, is there a channel for rates?
04 Sep 2016 08:01 #53462 by goebish
Rate is already set to expert.
04 Sep 2016 10:00 #53463 by chaotix
goebish wrote: Rate is already set to expert.
I thought that was the case, thanks. I'll just stick to putting silverwared boards in these frames then :)
04 Sep 2016 10:12 - 04 Sep 2016 10:23 #53464 by goebish
Yeah, I've ordered an E010 + a spare frame as well to try to use a "Silverxxxized" H8 mini FC on it ;)
(I already have a bunch of high KV 0615 Chaoli motors to go with them + 2 spare fx798t micro fpv pods)
Last edit: 04 Sep 2016 10:23 by goebish.
05 Sep 2016 02:38 #53480 by poohnyan
Replied by poohnyan on topic Eachine E010 inductrix clone data captures
Hey guys,I have a devo7e and devo10. I was able to bind in devo7e. However, in devo10 could not be bind.
Do not be bind in devo10? :unsure:
05 Sep 2016 10:15 #53492 by goebish
There's no reason, have you ever tried this module with another protocol to make sure it's working ?
05 Sep 2016 10:26 - 05 Sep 2016 10:27 #53494 by poohnyan
Yes. I am adding the 3in1 module in my DEVO10. CX10 and V202, MJX protocol is bind without any problems.
Thanks goebish :cheer:
Last edit: 05 Sep 2016 10:27 by poohnyan.
Time to create page: 1.202 seconds
