Eachine E010 inductrix clone data captures
- Alias_Hendrik
10 Sep 2016 20:55 - 10 Sep 2016 21:03 #53771
by Alias_Hendrik
Replied by Alias_Hendrik on topic Eachine E010 inductrix clone data captures
@ robocog
i posted my ini in the E010 thread from Sebydocky on rcgroups in the micro multi rotor section. i'ts a zip file with instruction which button to push for headless and RTH. But forgot to mention flip function which is on the Hold switch on the 7E.
Last edit: 10 Sep 2016 21:03 by Alias_Hendrik.
- robocog
10 Sep 2016 21:19 - 11 Sep 2016 07:32 #53772
by robocog
Replied by robocog on topic Eachine E010 inductrix clone data captures
Sorted, not sure what I was doing wrong, set to ch6 -100 and +100 (and verified in ch monitor) when toggle'd it does indeed flip
As a humble end user with little in the way of geek to add to the project I'd like to say a massive thanks to everyone on the teams efforts and hard work on this
You guys rock my world!
Regards
Rob
Late last night I also discovered that another of my nano quads (Flying Gadgets NanoQuad Xtra) binds and flys perfectly with the LS114 protocol
It's like Christmas and all Birthdays coming at once because now my Devo 7E flys/drives/sails all the toys I own
Regards
Rob
Last edit: 11 Sep 2016 07:32 by robocog.
- Stecozz
11 Sep 2016 10:28 #53785
by Stecozz
Replied by Stecozz on topic Eachine E010 inductrix clone data captures
Wish mine would bind.
Just installed the latest build but still no luck.
Just frustrating as my H8 mini flies great?
- goebish
- NRF Weirdo
11 Sep 2016 10:31 - 11 Sep 2016 10:33 #53786
by goebish
Replied by goebish on topic Eachine E010 inductrix clone data captures
Have you tried a version with hardcoded transmitter id ?
www.dropbox.com/s/o3zf621r3m8r01n/deviat...0-b289612#2.zip?dl=1
... or if you're using my latest build try a few different transmitter ID, I made a lot of tests last night and I found only 70-80% of transmitter IDs are working. At one point I thought I had found the rule, but no.
Last edit: 11 Sep 2016 10:33 by goebish.
- goebish
- NRF Weirdo
11 Sep 2016 14:27 #53790
by goebish
I just updated the test builds, it should bind with any transmitter ID now.
www.dropbox.com/sh/myda7gwpwfhkbw4/AABZS...QEt7BWI1BWDh7Ja?dl=0
- Arnold
11 Sep 2016 18:57 #53793
by Arnold
Are the changes also in the Nightly from 9-11-16? I'm looking for a build for my Devo F4. Thanks.
Replied by Arnold on topic Eachine E010 inductrix clone data captures
goebish wrote: I just updated the test builds, it should bind with any transmitter ID now.
- goebish
- NRF Weirdo
11 Sep 2016 18:59 #53794
by goebish
It's not in nightly yet, but here's a F4 build:
www.dropbox.com/s/akoc4s5i47kmcfy/deviat...0.0-6255503.zip?dl=1
- Arnold
11 Sep 2016 19:19 #53795
by Arnold
- Stecozz
12 Sep 2016 17:47 - 12 Sep 2016 17:49 #53820
by Stecozz
Thanks for the help but i still cant bind after all this.
even got another E010 to try but its no good
Guess i will use my H8 for FPV after all.
Maybe ive a faulty Nrl module?
Last edit: 12 Sep 2016 17:49 by Stecozz.
- Alias_Hendrik
12 Sep 2016 18:33 #53822
by Alias_Hendrik
Stecozz that's really weird. I too received today my second E010 and have no problem to bind it. if your other quads using a NRF bind ok your NRF module should be ok for the E010 too. You can always try my ini. It's in the Model config forum.
- Stecozz
12 Sep 2016 18:39 #53823
by Stecozz
I did Alias but its still not binding.
Heres my hardware file,is that ok?
Alias_Hendrik wrote: Stecozz that's really weird. I too received today my second E010 and have no problem to bind it. if your other quads using a NRF bind ok your NRF module should be ok for the E010 too. You can always try my ini. It's in the Model config forum.
- Alias_Hendrik
12 Sep 2016 19:11 #53824
by Alias_Hendrik
You should not use the windows notepad to edit ini's. Best to use Notepad++ for editing. Do you have only a single module installed? Only the NRF module and it's using A13? If so make a backup from your hardware ini and copy the one from the zip file to your Devo to try
- Stecozz
12 Sep 2016 19:24 #53825
by Stecozz
Thanks Alias
Ive just re flashed and installed the latest nightly again and it Binds!!!!
Just getting to grips with the switches,its flipping a lot haha
Thanks to everyones patience with me
- QuadBert
16 Sep 2016 16:48 #53920
by QuadBert
Replied by QuadBert on topic Eachine E010 inductrix clone data captures
I could not get my E010 to bind to my 7e with the fixed ID, but after clearing out the ID it would bind. I'm using the latest nightly build.
I've noticed, though, that during flight, it will intermittently start flashing rapidly like it is not bound. I haven't had any time to test that more thoroughly. It seems to work, although it is VERY sensitive on the throttle. As soon as I get a chance I will try to determine if it is losing control while it is blinking. I also have another E010 still in the box, that I can open up and try.
- bevik
17 Sep 2016 16:04 #53967
by bevik
Replied by bevik on topic Eachine E010 inductrix clone data captures
i was able to bind my devo10 with the e010 initially but after changing some setting my binding failed. It appears to be the Tx power that caused the issue it SHOULD BE SET TO 10mW. At 30mW i can bind occassionally and on those time that i manages to bind there is a chance that the bind will break, and 100mW wont allow me to bind. Hope this information helps!
- Alias_Hendrik
17 Sep 2016 22:09 #53981
by Alias_Hendrik
I have only a NRF module (in my 7E). I can bind both my red and green E010 on 30mW or 100mW without problem.
- bevik
18 Sep 2016 02:19 #53985
by bevik
that's interesting. I'm on the 3 in 1 module, which i have just installed. and i only have a green e010 to try out the module.currently using the 15sept nightly build. I wonder did i have a poor solder for my module, the first time i tested my module i had a Missing Modules: CYRF6936 message. The message doesn't go away, I had to resolder some of the joints then it worked.
- epilot
19 Sep 2016 21:58 #54043
by epilot
Replied by epilot on topic Eachine E010 inductrix clone data captures
bevik, would you mind sharing your model.ini file? I'm having trouble getting my Devo10 to bind with the E010.
- bevik
20 Sep 2016 17:32 #54071
by bevik
As requested E010 model file (devo10)
- mr_tucsons
25 Sep 2016 16:25 #54253
by mr_tucsons
Replied by mr_tucsons on topic Eachine E010 inductrix clone data captures
Hello.. im new to deviation firmware. Can i bind E010 to my devo 8? How it can be done? Thanks
Time to create page: 0.381 seconds
- Eachine E010 inductrix clone data captures
