Mjx Bugs 3
- C0ckpitvue 777
01 Feb 2018 11:31 #67354
by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic Mjx Bugs 3
Yes Seby that is correct,I also took a couple of captures in that sequence.Remember there are 2 different protocols to the bugs 3 but I'm sure like me you have the original version and we need all the help we can with captures it I will definitely welcome and appreciate your help.I am donating mine to deviation so hexfet has the entire knowledge of the model,I will get a new one soon.
- C0ckpitvue 777
02 Feb 2018 17:19 #67364
by C0ckpitvue 777
I tried the last test build to no avail,although I didn't scan the fine frequency this time.It's on it's way to you,I will pm you the tracking info..
- Blade81
12 Feb 2018 23:31 #67477
by Blade81
Replied by Blade81 on topic Mjx Bugs 3
I am really looking forward to be able to use t8sg on bugs 3 and i thank you guys for all the work. If there is anything i can do to help.
On a side note, a friend of mine recently got his bugs 3. He need to hold the red button and power on the tx to intiate bind for the first time. Subsequently he doesnt need to do that anymore
- davdrone1
- davdrone1
13 Feb 2018 00:29 #67478
by davdrone1
Time flies like a banana
Replied by davdrone1 on topic Mjx Bugs 3
I usually hold the red button down then turn on the TX for most flights, I then calibrate by pushing both sticks down and right. If I don't do this, sometimes the motors will not start when I press the red button to arm. I also often need to do this if I use a different controller on my second Bugs 3, or the Bugs 6. Doing this, I can mix and match all Txs and Bugs.
On a related topic, my USB Mini B female connectors have arrived, and I should soon have time to replace the USB port on my Jumper T8SG, and get back to downloading and testing test builds. Looking forward to helping out again.
23 Feb 2018 22:12 #67724
Replied by hexfet on topic Mjx Bugs 3
Unfortunately the bugs3 that C0ckpitvue 777 sent to me is lost. I filed a claim with USPS. The carrier states they delivered to the correct address, but the customer service rep said the delivery GPS scan was down the road somewhere. Waiting to hear more.
- C0ckpitvue 777
24 Feb 2018 00:29 #67725
by C0ckpitvue 777
Thanks for the update,I do have an extra tx if someone cares to donate a bugs 3 we can send to hexfet.Remember he puts in good work for the devo community on his own time.I was really thinking about getting the bugs 6 and taking captures as banggood has it on sale for 74.00 bucks after coupon code.Was wondering if Seby Docky was doing captures for this bird?
26 Feb 2018 01:40 #67773
The bugs3 test builds are updated. Reviewed the captures and code and found some issues with the bind sequence. This build has a better chance of binding.
- C0ckpitvue 777
26 Feb 2018 01:44 #67774
by C0ckpitvue 777
Thanks Hexfet,I hope someone can test this with the jumper or either the devo.
hexfet wrote: The bugs3 test builds are updated. Reviewed the captures and code and found some issues with the bind sequence. This build has a better chance of binding.
- Blade81
27 Feb 2018 00:51 #67796
by Blade81
I have a bug3 and a jumper. I love to help but im not sure how to go about it
- C0ckpitvue 777
27 Feb 2018 01:00 #67797
by C0ckpitvue 777
Blade81 wrote: I have a bug3 and a jumper. I love to help but im not sure how to go about it[/quote
If the Jumper is anything like the devo just download the latest nightly builds,it is under the hubsan protocol in the sub menu.
27 Feb 2018 01:34 - 27 Feb 2018 01:35 #67798
Bugs3 has it's own protocol. It's after Joysway as you scroll through the protocols. Download and install the t8sg
test build from here
, select the bugs3 protocol, then see if you can bind to your bugs3.
Last edit: 27 Feb 2018 01:35 by hexfet.
- Blade81
27 Feb 2018 02:11 #67799
by Blade81
I will try it tonight and update the results later
- C0ckpitvue 777
27 Feb 2018 02:24 #67801
by C0ckpitvue 777
Thanks fellas.
- Blade81
27 Feb 2018 13:26 #67806
by Blade81
i had tested but doesn't seem to work. at times i see the lights goes stable. which is sign of bind, but when i off the transmitter, lights stay steady instead of flashing.
i uploaded the video of me testing it. hope it helps.
27 Feb 2018 22:27 - 27 Feb 2018 22:28 #67813
Thanks, the video is helpful. Yes the lights are confusing though. They don't seem to behave like the manual says.
Would you please try the bind procedure that is at the top of page 8 in the pdf manual? The procedure is to start with the aircraft powered off, then put the tx in bind mode, then power on the aircraft. If it works the t8sg will exit bind mode automatically.
Please be careful. Until the protocol is completely worked out the aircraft may react dangerously if bind is successful, such as spinning the props and unknown throttle value. Suggest removing the props for testing.
Last edit: 27 Feb 2018 22:28 by hexfet.
- Blade81
27 Feb 2018 23:03 #67815
by Blade81
I will do it tonight and update the result. Thanks for the heads up i will remove the props for testing
- davdrone1
- davdrone1
28 Feb 2018 09:42 #67821
by davdrone1
I managed to fix the USB port on my Jumper T8SG, and to try out the latest test build. Turning the Jumper on first, then connecting the Bugs 3 to battery, the lights on the Bugs flash, and then stay on as per a normal bind. However, there are no notes played, and the Bugs 3 does not respond to moving both joysticks down and right by flashing lights as per a normal bind. There is no response to the throttle. I have a second Bugs 3 and a Bugs 6. I will test them tomorrow.
- Blade81
28 Feb 2018 11:15 #67825
by Blade81
As per binding sequence. I tried twice and i believe the 2nd bind was sucessful. But channel controls are out. I believe the orignal tx initiate the bind command to the drone which cause it to imediately arm. Luckily my props are off as recommended by hexfet
28 Feb 2018 15:17 #67828
Interesting. The t8sg never received data from the quad to end the bind, but still had some effect since turning on the stock tx caused the motors to immediately start. Need to review the code to come up with the next test.
- FlyBuy66
28 Feb 2018 16:49 #67829
by FlyBuy66
Replied by FlyBuy66 on topic Mjx Bugs 3
Hexfet. I've got to give you 2 thumbs up for the hard work you are putting into this project. I would try to be more help but I'm only working with a flysky I6. I can't understand how NO ONE has been able to crack the arming of the Bugs 3 so it could be flown with any of a number of popular TX. I keep getting the updates on this project and it is very exciting. Who knows...if it gets cracked, I'll have to go buy a Jumper!
Thanks for all your doing Hex....have a productive day!
Time to create page: 0.910 seconds
- Mjx Bugs 3
