iRangeX iRX-IR8M V2
- goebish
- NRF Weirdo
07 Feb 2019 15:14 #72772
by goebish
Replied by goebish on topic iRangeX iRX-IR8M V2
Looks like an hardware issue (defective Power Amplifier in the 4-in-1 module ?), I'm sorry but I can't help more. Contact banggood, but they won't reply until the 15th because of Chinese new year, and they'll probably ask for a video of the problem, which might not be easy ...
- david drones
07 Feb 2019 15:16 #72773
by david drones
Replied by david drones on topic iRangeX iRX-IR8M V2
tell me the 4 in 1 is changing ??? or buy a 4 in 1 that works well ????
- goebish
- NRF Weirdo
07 Feb 2019 15:19 #72774
by goebish
I think banggood / gearbest / aliexpress has stopped selling this kind of module as spare parts. Now they only have modules for Devo transmitters.
Anyway, it almost costs the price of a IR8M ... If you ever get a refund for yours I'd recommend getting a T8SG V2 (not lite) instead.
- david drones
07 Feb 2019 15:23 #72775
by david drones
do you have a link for radiocommande that you advise me please
- goebish
- NRF Weirdo
07 Feb 2019 15:30 - 07 Feb 2019 15:30 #72776
by goebish
www.banggood.com/Jumper-T8SG-Plus-V2_0-M...=FO0318156274201304X
Maybe you can find a better price or wait for a promo sale.
Last edit: 07 Feb 2019 15:30 by goebish.
- goebish
- NRF Weirdo
07 Feb 2019 15:33 - 07 Feb 2019 15:37 #72777
by goebish
There's one for sale for 65€ on "Le Coin Coin du FPV" on facebook:
www.facebook.com/groups/571655186331296/..._id=1214387965391345 (you need to be a member of the group)
You may get it if you're quick enough
edit: that's a T8SG V2, not a T8SG V2 Plus, the gimbals are not as good but that's still a good transmitter.
Last edit: 07 Feb 2019 15:37 by goebish.
- goebish
- NRF Weirdo
07 Feb 2019 22:27 - 07 Feb 2019 22:38 #72780
by goebish
There's something you can try, in AFHDS-2A protocol options (click the protocol name in Model Settings menu), try to change "FREQ TUNE" value, in 20 KHz steps then check if that's better.
Last edit: 07 Feb 2019 22:38 by goebish.
- david drones
07 Feb 2019 22:37 #72781
by david drones
good evening I thank you again for your help, yes I too had to think of modifying in the menu: AFHDS-2A, is to begin at the end of different afternoons test
original configure 50hz i sui now at 250 hz with another antenna, than that, original is got a better result inside my house i will give it a try tomorrow, and you keep informed, if you have any other idea, I take it with pleasure, thank you again
- goebish
- NRF Weirdo
07 Feb 2019 22:38 - 07 Feb 2019 22:39 #72782
by goebish
You're only interested in modifying FREQ TUNE, the other settings won't have any effect on your problem.
Last edit: 07 Feb 2019 22:39 by goebish.
- david drones
07 Feb 2019 22:47 #72783
by david drones
you may still be able to help me, I do not understand what I change, but my (au4) who my big black knurl left, when I turn to the bottom right, my remote control is gone, ?? I do not understand why it did not do it today and yesterday, maybe I change some things in the parameters, that it was not necessary when you think, please
- david drones
07 Feb 2019 22:50 #72784
by david drones
vous pouvez peut etre encore m'aider, je ne comprend pas ce que j'ai modifier ,mais mon( aux4) qui ma grosse molete noir de gauche, quand je la tourne a fond à droite , ma telecommande s'eteind,???je ne comprend pas pourquoi cela ne le fesais pas aujourd'hui et hier, peut etre j'ai modifier quelques choses dans les parametres, qu'il ne fallais pas ???quand penser vous ,s'il vous plait
08 Feb 2019 05:36 - 08 Feb 2019 05:48 #72805
goebish, I suspect that factory firmware use modified HAS_4IN1_FLASH support, and Deviation version doesn't switch 4in1 module PA lines (PE1 (3) and PE2 (4)). It can be tested with different protocols, probably IR8M has normal output power for one RF chip only (CC2500, NRF24L01, A7105, CYRF6936).
Replied by vlad_vy on topic iRangeX iRX-IR8M V2
goebish wrote: Looks like an hardware issue (defective Power Amplifier in the 4-in-1 module ?), I'm sorry but I can't help more. Contact banggood, but they won't reply until the 15th because of Chinese new year, and they'll probably ask for a video of the problem, which might not be easy ...
GabrielRB wrote: My recommendation for all people having range issues is roll back to original firmware.
With original firmware I get >2km with FrSky receivers
Last edit: 08 Feb 2019 05:48 by vlad_vy.
- david drones
08 Feb 2019 07:56 #72808
by david drones
Bonjour je vous remercie encore pour votre aide j'ai remis Le firmware d originale avec une antenne extérieure qui visiblement me donne une meilleure réception au niveau du RSSI par contre maintenant j'ai un réel problème pour lequel j'ai vraiment besoin de vos connaissances car je ne comprends pas j'ai passé plusieurs heures cette nuit à chercher sans aucun résultat quand je manipule mon auxiliaire 4 de ma radiocommande le potard noir en haut à gauche cela coupe ma radiocommande et je suis obligé d'attendre plusieurs secondes avant de pouvoir allumer ma radio commande j'ai vraiment cherché dans tous les menus et sous-menu sans aucun succès encore vraiment désolé de vous déranger et de vous solliciter pour votre aide mais je suis vraiment perdu et ne comprends pas pourquoi d'un seul coup ma radiocommande se coupe dès que je fais l'utilisation de mon auxiliaire 4 je vous remercie encore d'avance de votre temps passer à m'aider et d'être solidaire encore vraiment merci de votre part à tous attends avec impatience de vos nouvelles je vous tiendrai informé sur votre site de la remise à niveau de ma télécommande et de la différence apporté
Hello I thank you again for your help I gave the original firmware with an outdoor antenna that obviously gives me a better reception at the RSSI by cons now I have a real problem for which I really need your knowledge because I do not understand I spent several hours that night searching without any results when I manipulate my auxiliary 4 of my radio control knob black top left it cuts my radio control and I have to wait several seconds before I can turn on my radio control I really searched all the menus and submenu without any success yet really sorry to bother you and ask you for your help but I'm really lost and do not understand why in one fell swoop my radio control cut off as soon as I make the use of my auxiliary 4 I thank you again in advance of your time to help me and to be supportive again really thank you you all eagerly awaiting your news I will keep you informed on your website of the refurbishment of my remote control and the difference made
- goebish
- NRF Weirdo
08 Feb 2019 11:48 - 08 Feb 2019 11:48 #72813
by goebish
@vlad_vy that's a possibility ... too bad iRangeX didn't offer to send a few transmitters to developers ...
@david drones, please share your modelXX.ini, I'll try to reproduce your issue.
Last edit: 08 Feb 2019 11:48 by goebish.
- david drones
08 Feb 2019 11:51 #72814
by david drones
Thank you for helping @Goebish, but I do not understand what you expect from me, waiting for your news again thank you
- goebish
- NRF Weirdo
08 Feb 2019 14:01 - 08 Feb 2019 14:01 #72817
by goebish
Connect your transmitter to your computer in USB/FileSystem mode (hold Enter button then switch on transmitter) then post the model file that crashes when you move AUX4.
Last edit: 08 Feb 2019 14:01 by goebish.
- david drones
08 Feb 2019 20:28 #72823
by david drones
bonsoir à tous et encore merci pour votre aide je vous joint comme demander par @goebish les informations fichier erreurs:
[Hard fault]
t8sg-v5.x.x-2017-09-19
R0 = 00000000
R1 = 000000e1
R2 = 00000000
R3 = 0802bedd
R12 = 00000030
LR [R14] (subroutine call return address) = 0802d645
PC [R15] (program counter) = 0802d646
PSR = 81000000
BFAR = e000ed38
CFSR = 00000400
HFSR = 40000000
DFSR = 00000000
AFSR = 00000000
SCB_SHCSR = 00000000
Top of Stack:2000c000
Stack Detect:2000bf88
Backtrace:
2000bf94 : 0802bedd
2000bf9c : 0802d645
2000bfac : 0802d8bf
2000bfb0 : 0802bedd
2000bfbc : 0802bf0f
2000bfc0 : 0802bedd
2000bfc4 : 080291e3
2000bfcc : 08029687
2000bfdc : 0800b4fb
2000bfec : 0800b5ef
2000bffc : 080333c9
Done
pour information j'ai résolu le problème de l'auxilaire 4 un fils de mal branché fessait une mauvaise masse
il me reste plus qu'a résoudre mon problème avec ma radiocommande qui eteind le signal passer les 90 mètres et je serai le plus heureux du monde,mais je sais très bien, que cela, sera garce, à votre aide
[Hard fault]
R0 = 00000000
R1 = 000000e1
R2 = 00000000
R3 = 0802bedd
R12 = 00000030
PSR = 81000000
BFAR = e000ed38
CFSR = 00000400
HFSR = 40000000
DFSR = 00000000
AFSR = 00000000
Backtrace:
2000bf94 : 0802bedd
2000bf9c : 0802d645
2000bfac : 0802d8bf
2000bfb0 : 0802bedd
2000bfbc : 0802bf0f
2000bfc0 : 0802bedd
2000bfc4 : 080291e3
2000bfcc : 08029687
2000bfdc : 0800b4fb
2000bfec : 0800b5ef
2000bffc : 080333c9
Done
- david drones
08 Feb 2019 20:29 #72824
by david drones
good evening to all and thank you again for your help Please contact us by @goebish the file information errors:
[Failure]
t8sg-v5.xx-2017-09-19
R0 = 00000000
R1 = 000000e1
R2 = 00000000
R3 = 0802bedd
R12 = 00000030
LR [R14] (subroutine return address) = 0802d645
PSR = 81000000
BFAR = e000ed38
CFSR = 00000400
HFSR = 40000000
DFSR = 00000000
AFSR = 00000000
SCB_SHCSR =
0000
Battery Detection: 2000bf88
backtrace:
2000bf94: 0802bedd
2000bf9c: 0802d645
2000bfac: 0802d8bf
2000bfb0: 0802bedd
2000bfbc: 0802bf0f
2000bfc0: 0802bedd
2000bfc4: 080291e3
2000bfcc: 08029687
2000bfdc: 0800b4fb
2000bfec: 0800b5ef
2000bffc: 080333c9
Completed
information for the i solved the auxilaire problem 4 a badly plugged son spanked a bad mass
I have more than solve my problem with my radio control that has passed the signal to 90 meters and that I would be happier with the world, but that I know very well, that it will be, to your help
[Failure]
R0 = 00000000
R1 = 000000e1
R2 = 00000000
R3 = 0802bedd
R12 = 00000030
PSR = 81000000
BFAR = e000ed38
CFSR = 00000400
HFSR = 40000000
DFSR = 00000000
AFSR = 00000000
SCB_SHCSR =
0000
backtrace:
2000bf94: 0802bedd
2000bf9c: 0802d645
2000bfac: 0802d8bf
2000bfb0: 0802bedd
2000bfbc: 0802bf0f
2000bfc0: 0802bedd
2000bfc4: 080291e3
2000bfcc: 08029687
2000bfdc: 0800b4fb
2000bfec: 0800b5ef
2000bffc: 080333c9
Completed
- david drones
08 Feb 2019 20:38 #72825
by david drones
sincerement je voudrais donner un grand merci à Monsieur @goebish qui n'a pas arreter de m'aider
honnetement c'est très difficile pourmoi de comprendre d'ou vient le probleme,je ne pensais pas cela possible ,mais heureusement des homme comme Monsieur @goebish
sont là et vous aide pour avancer de 'lombre à la lumiere
et meme si mon probleme est toujours present cela fais vraiment plaisir d'etre soutenu et aider
Merci Monsieur @goebish et les autres bien sur aussi
sincerely i would like to give a big thank you to mister @goebish who did not stop helping me
honestly it's very difficult for me to understand where the problem comes from, I did not think that was possible, but fortunately men like Mr. @goebish
are there and help you to move from 'darkness to light'
and even if my problem is still present it's really nice to be supported and help
Thank you Mr. @goebish and the others of course too
- david drones
08 Feb 2019 23:50 #72828
by david drones
Good evening I would just like a confirmation
The iRangeX iRx-IR8M V2 radio remote control accepts lipo in 2S ??? or not !!!
Thank you for kindly answering me, before I face the test and destroy the radio remote control
if a person, know, the maximum voltage and maximum amperage also it will be great
thank you in advance
Time to create page: 1.176 seconds
- iRangeX iRX-IR8M V2
