Jumper T8SG V2 Plus and Crossfire
06 Jun 2019 08:51 - 06 Jun 2019 08:52 #74462 by skullq
Replied by skullq on topic Jumper T8SG V2 Plus and Crossfire
hexfet wrote: A pic might help spot a PCB issue. I have this tx so can compare.
My issue was the TX pin wasn't inserted properly. After disassembling TX I tried to put crossfire micro module socket into the pin directly and the ring started illuminating.
Another issue is I can't enter crsf menu with nightly build 9fd50b5. Let me know crsf menu supported nightly build?
Last edit: 06 Jun 2019 08:52 by skullq.
06 Jun 2019 14:13 #74464 by hexfet
Replied by hexfet on topic Jumper T8SG V2 Plus and Crossfire
Glad you got it sorted. The CRSF configuration feature is not yet in the nightly builds. The test build here is up-to-date with the nightly builds.
07 Jun 2019 07:55 #74471 by skullq
hexfet wrote: Glad you got it sorted. The CRSF configuration feature is not yet in the nightly builds. The test build here is up-to-date with the nightly builds.
Really appreciate your help and contribution on crsf support!!
Without your effort we can't use crsf in deviation with t8sg.
14 Jun 2019 13:12 #74531 by Pepe
Replied by Pepe on topic Jumper T8SG V2 Plus and Crossfire
New update 6/6/19?
14 Jun 2019 13:54 #74532 by hexfet
There's no changes to CRSF in the test build link above. It just updates the test build with other recent changes in the nightly build.
13 Jul 2019 09:03 #74739 by yoodog
Replied by yoodog on topic Devo + Crossfire
Hey :)
Any one has info if we can run Crossfire on Devo 8s (ready to cut plastic and make it fit), but ppm out is not an option - delay is to much after conventional 2.4ghz racing.... Otherwise any solution on long rage TX/RX with SBUS and RSSI for Devo?
13 Jul 2019 23:58 #74744 by hexfet
Replied by hexfet on topic Devo + Crossfire
On the devo transmitters the CRSF signal appears on the TX pin (tip) of the trainer port. Connect that to the module CRSF input, and connect grounds together. The CRSF input on the TBS module is the bottom JR pin - not sure where that connects on the TBS itself.
27 Aug 2019 11:30 #75030 by Pavel
Replied by Pavel on topic Jumper T8SG V2 Plus and Crossfire
Hi skullq, can I ask You a support regarding Jumper T8SG V2 Plus? I have probably the same revision You have, with voice support already embedded (the PCB is T8SG-V3-PLUS). I updated FW and file system, but didn't make a backup of "hardware.ini" file. So I lost voice support. Can You, please, provide me with Your "stock" hardware.ini config file? Thank You a lot in advance for this.
28 Aug 2019 11:18 #75046 by yoodog
Great thanks! Still desiding which one would work better on 8s TX - CRSF or new R9M Light Pro TX, 1w now, + Nano RX with over the air update :-D
is R9M Light Pro connection possible ? Which one is better integrated R9M or Crossfire in your opinion?
02 Sep 2019 14:46 #75076 by skullq
Hi pavel,
Here is my hardware.ini
;enable-haptic=1
;switch_types: 3x4, 3x3, 3x2, 3x1, 2x8, 2x7, 2x6, 2x5, 2x4, 2x3, 2x2, 2x1, potx2, potx1
;Add nostock if stock FMOD and HOLD switches have been removed.
extra-switches = nostock
extra-switches = 3x4
extra-switches = 2x2
extra-switches = potx2
;Audio player connected to UART (Devo12/S internally, others via trainer port): audiofx, dfplayer
voice=dfplayer
;Enable if audio device is wired to uart5 instead of ppm on devo7e-256
voice-uart5=1
;extra-buttons=
[modules]
; enable-cyrf6936 = B12
; has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = A15
has_pa-nrf24l01 = 1
; enable-multimod = A13
04 Sep 2019 23:19 - 04 Sep 2019 23:20 #75079 by hexfet
yoodog wrote: Great thanks! Still desiding which one would work better on 8s TX - CRSF or new R9M Light Pro TX, 1w now, + Nano RX with over the air update :-D
Looks like fully supporting the Light Pro requires adding PXX2 protocol. Won't be able to look at that till next month. Last I asked Frsky wouldn't share the PXX specification so it'll have to be deciphered from opentx or ersky.
The crsf_configuration test build supports configuring the Crossfire tx and rx through deviation.
Last edit: 04 Sep 2019 23:20 by hexfet.
15 Sep 2019 05:52 #75107 by t0t0 FPV
Replied by t0t0 FPV on topic Devo + Crossfire
I go the T8SG plus 2 carbon and I did the hardware modification and it works well with crossfire (crsf v2) (stock firmware)
@hexft: Should I upgrade the radio with the crsf firmware that you did ? What are the benefits right now ?
17 Sep 2019 02:22 #75109 by hexfet
The crsf_configuration test build supports configuring the TBS devices by clicking on the protocol name. The control and telemetry code is the same as the nightly build.
17 Sep 2019 07:33 #75113 by gerikov
Replied by gerikov on topic Jumper T8SG V2 Plus and Crossfire
Hi guys ! Please tell me where can i download final firmware supported CF and what limitation at the moment does it have ?
Thx in advance
17 Sep 2019 07:54 #75114 by Pavel
Many many thanks, skullq!
18 Sep 2019 19:37 #75123 by hexfet
gerikov wrote: Hi guys ! Please tell me where can i download final firmware supported CF and what limitation at the moment does it have ?
Thx in advance
The nightly builds (under Downloads on the left) have CRSF support for control and telemetry.
The crsf_configuration test build adds support for configuring the Crossfire devices through deviation.
08 Nov 2019 11:38 - 08 Nov 2019 11:38 #75417 by Hans-Udo
Replied by Hans-Udo on topic Jumper T8SG V2 Plus and Crossfire
I have the same issue as skullq. I Think the pins of the module connector to short. When I remove the back cover and put the crossfire on the pins the LED illuminate but with the cover nothing happens.
a little youtube Video it shows the issue
Skullq how do you solve it?
Last edit: 08 Nov 2019 11:38 by Hans-Udo.
09 Nov 2019 08:49 #75426 by skullq
My issue was mostly same but pin length was not short. PIN just didn't properly aligne between TX and crossfire module.
Try to align crossfire module on left or right bay while you inserting the module. you may understand my point. lol
10 Nov 2019 14:08 #75431 by Hans-Udo
Hi Skullq, thank you very much!
I screwed the Micro tx apart, put the lower part into the jumper, put the board on the pins, switched it on and the LED shone. :) I screwed the board back on and mounted the lid. Now it works and I will never get the module out again. ;)
13 Dec 2019 11:51 #75571 by Konatsu
Replied by Konatsu on topic Jumper T8SG V2 Plus and Crossfire
I've just bought Crossfire Micro TX and im unable to configure it on T8SG v2 Plus
I did hardware mod with removing firs pin and connecting it to last pin.
Crossfire module is blinking yellow and nothing is happening when i press enter on CRSF in model setup.
I'm on latest firmware, t8sg_v2_plus-v5.0.0-abcac7f.
What i'm missing?
Time to create page: 1.600 seconds
