Devo F7 and iLook+ FPV screen issue
- pugnot
31 May 2015 23:42 #33297
by pugnot
Devo F7 and iLook+ FPV screen issue was created by pugnot
Hi, recently replaced my iLook with an iLook+. now the lower status gauges on the the FPV screen of my devo F7 are just below the visible line on the screen.
I can just see the tops of the numbers.
How can I adjust this so I can see the numbers again?
31 May 2015 23:52 #33298
Replied by PhracturedBlue on topic Devo F7 and iLook+ FPV screen issue
I don't know whether this is possible or not. We are close to having Deviation working on the F7 (it actually works now, but still needs some additional work). In deviation, you can adjust the display to put the elements back on the screen if needed.
- pugnot
31 May 2015 23:54 #33299
by pugnot
Replied by pugnot on topic Devo F7 and iLook+ FPV screen issue
Good news, where are the adjustments you mention to adjust the display?
01 Jun 2015 01:50 #33301
Note that I said 'Deviation'. you need to install the custom firmware, which isn't actually availableyet unless you build it yourself. Please read the front page of this site to understand that we are developing a independant firmware to replace the stock firmware from Walkera. We are completely not affiliated with Walkera, and Deviation is unrelated to the stock Devention firmware.
- SemajDrone
12 Sep 2015 08:32 #37675
by SemajDrone
Replied by SemajDrone on topic Devo F7 and iLook+ FPV screen issue
Hello
Time to create page: 0.223 seconds
Stock Firmware Help
- Devo F7 and iLook+ FPV screen issue
