Please Original Firmware DEVO F8S
27 Jul 2018 06:52 #69962
Please Original Firmware DEVO F8S was created by FDR
I didn't even know about the F8S, but the difference is night and day.
Look:
www.aliexpress.com/item/Walkera-DEVO8S-T...itter/601865371.html
Why do you need a fw for yours?
Look:
27 Jul 2018 07:47 #69966
Replied by FDR on topic Please Original Firmware DEVO F8S
Does the TX use a smartphone as a display through WiFi?
Did you change it in the TX menu?
If so, then it is only a setting stored somewhere in flash, and a fw upgrade won't necessarily overwrite it, so the problem will remain.
Am I right, that now the TX try to send the display info through an 5.8GHz video channel?
Try to find somebody with an FPV display or googles, and change the setting back to WiFi...
27 Jul 2018 08:25 #69970
No, the TX uses an internal flash chip to store settings or stores them inside the microcontroller's own flash area.
You can't change it directly, only through the user interface.
Were my previous assumptions right about the smartphone as a display?
- Stead1984
09 Apr 2020 09:01 #76167
by Stead1984
Replied by Stead1984 on topic Please Original Firmware DEVO F8S
Kathvings ..... Did you ever get a reset for the controller?
I've got the exact same issue.
I followed the advice from the Walkera website and changed the channels, but the guidance is wrong. It tells you to change Radio 1 channel (which is between the controller and device), when actually it should have had you changing the Radio 2 channel (between the drone and controller).
I have tried several different devices and none of them are picking up the Walkera _Ground wifi signal.
I think the only fix is a Master reset.
Please help.
Eddy
Please help.
Eddy
Time to create page: 0.045 seconds
Stock Firmware Help
- Please Original Firmware DEVO F8S
