development:building_on_windows [2016/04/15 19:03]
PhracturedBlue [Running Emulator]
development:building_on_windows [2016/04/30 08:17] (current)
PhracturedBlue
Line 1: Line 1:
 ===== Development on Windows ===== ===== Development on Windows =====
-==== Install ​MingW ==== +**NOTE: It is now strongly recommended that you use Docker images to build Deviation. ​ Instructions for building can be found [[development:​docker | here]]**
-  * [[http://​sourceforge.net/​projects/​mingw/​files/​Installer/​mingw-get-inst/​mingw-get-inst-20120426/​mingw-get-inst-20120426.exe/​download||Download]] ​the mingw installer+
 +''​Note,​ these instructions may be out of date.  Please help to make them current''​
 +==== Install ​MinGW ====
 +  * [[http://​sourceforge.net/​projects/​mingw/​files/​Installer/​mingw-get-inst/​mingw-get-inst-20120426/​mingw-get-inst-20120426.exe/​download|Download ​the MinGW installer]]
   * Run the installer, and select '​C++',​ '​MSYS'​ and the '​Developer Toolkit'​   * Run the installer, and select '​C++',​ '​MSYS'​ and the '​Developer Toolkit'​
-==== Install ​fltk ==== +==== Install ​FLTK ====
-  * [[http://​www.fltk.org/​software.php?​VERSION=1.3.0&​FILE=fltk/​1.3.0/​fltk-1.3.0-source.tar.gz|Download]] ​fltk+  * [[http://​www.fltk.org/​software.php?​VERSION=1.3.0&​FILE=fltk/​1.3.0/​fltk-1.3.0-source.tar.gz|Download ​FLTK]]
   * Start msys (you should have an icon, but otherwise run C:​\MingW\msys\1.0\msys.bat   * Start msys (you should have an icon, but otherwise run C:​\MingW\msys\1.0\msys.bat
   * mkdir src   * mkdir src
Line 15: Line 18:
   * make install   * make install
-==== Install ​portaudio ​==== +==== Install ​PortAudio ​====
-  * [[http://​www.portaudio.com/​archives/​pa_stable_v19_20111121.tgz|Download]] ​portaudio+  * [[http://​www.portaudio.com/​archives/​pa_stable_v19_20111121.tgz|Download ​PortAudio]]
   * cd src   * cd src
Line 26: Line 29:
 ==== Install Deviation ==== ==== Install Deviation ====
-  * Download the source code for deviation. You'll need mercurial to keep track of changes (which will require installing python), but you can manually download a zip of the source from https://​github.com/​DeviationTX/​deviation+  * Download the source code for deviation. You'll need mercurial to keep track of changes (which will require installing python), but you can manually download a zip of the source from the [[https://​github.com/​DeviationTX/​deviation|GitHub deviation repository]]
   * cd ~/src   * cd ~/src
   * cp -pf <path to deviation src code> deviation   * cp -pf <path to deviation src code> deviation
development/building_on_windows.1460772225.txt.gz (12799 views) · Last modified: 2016/04/15 19:03 by PhracturedBlue
