| Line 5: | Line 5: | ||
| ==== Building for ARM (on Linux) ==== | ==== Building for ARM (on Linux) ==== | ||
| - | - download and install the precompiled linux compiler from here: https://launchpad.net/gcc-arm-embedded | + | - download and install the pre-compiled Linux compiler from here: https://developer.arm.com/open-source/gnu-toolchain/gnu-rm/downloads |
| - | * Note that the only supported compiler for Deviation is gcc-arm-none-eabi-4_8-2013q4-20131204. You can find the link to this from here: https://launchpad.net/gcc-arm-embedded/+download | + | * Note that the only supported compiler for Deviation is gcc-arm-none-eabi-8-2018-q4. You can find the link to this from here: https://developer.arm.com/-/media/Files/downloads/gnu-rm/8-2018q4/gcc-arm-none-eabi-8-2018-q4-major-linux.tar.bz2 |
| - Add the path to the 'bin' directory to your PATH | - Add the path to the 'bin' directory to your PATH | ||
| ==== Building for ARM (on Windows) ==== | ==== Building for ARM (on Windows) ==== | ||
| - | - Download and install the precompiled windows compiler from here: https://launchpad.net/gcc-arm-embedded | + | - Download and install the precompiled windows compiler from here: https://developer.arm.com/open-source/gnu-toolchain/gnu-rm/downloads |
| - | * Note that the only supported compiler for Deviation is gcc-arm-none-eabi-4_8-2013q4-20131204. You can find the link to this from here: https://launchpad.net/gcc-arm-embedded/+download | + | * Note that the only supported compiler for Deviation is gcc-arm-none-eabi-8-2018-q4. You can find the link to this from here: https://armkeil.blob.core.windows.net/developer/Files/downloads/gnu-rm/8-2018q4/gcc-arm-none-eabi-8-2018-q4-major-win32.zip |
| - Add path to 'bin' directory to your PATH (I like to put this into ~/.profile so it is there each time I start msys): ''export PATH=/mingw/stm32/bin:$PATH'' | - Add path to 'bin' directory to your PATH (I like to put this into ~/.profile so it is there each time I start msys): ''export PATH=/mingw/stm32/bin:$PATH'' | ||
| - Ensure python is installed. If not install it from here: http://www.python.org/download/releases/2.7.3/ | - Ensure python is installed. If not install it from here: http://www.python.org/download/releases/2.7.3/ | ||
| Line 65: | Line 65: | ||
| * cp -pf <path to deviation src code> deviation | * cp -pf <path to deviation src code> deviation | ||
| * cd deviation/src | * cd deviation/src | ||
| + | ==== Building Deviation ==== | ||
| + | * The default build target is the devo8 transmitter. If you type ''make'' in the deviation/src directory this is what you will get. | ||
| + | * Other transmitters can be specified on the make cmdline: ''make devo10 devo7e'' | ||
| + | * Creating packaged zip files can be done by pre-pending 'zip_': ''make zip_devo10'' | ||
| + | * Building the emulator is done by pre-pending 'emu_': ''make emu_devo8'' or ''make zip_emu_devo8'' | ||
| + | * Building the windows version of the emulator can be done vie: ''make win_emu_devo8'' or ''make zip_win_emu_devo8'' | ||
development/setting_up_build_env.1462027838.txt.gz (4400 views) · Last modified: 2016/04/30 07:50 by PhracturedBlue
