hardware:jumper_t12
hardware:jumper_t12 [2019/01/26 05:35]
PhracturedBlue
hardware:jumper_t12 [2019/04/26 15:22] (current)
goebish [FCC Report]
Line 6: Line 6:
   * Radio: Jumper 4-in-1 module plugged into the back of the transmitter   * Radio: Jumper 4-in-1 module plugged into the back of the transmitter
   * 256kbit EEPROM: ST M24256   * 256kbit EEPROM: ST M24256
 +  * Volume control: LM4875 - Controlled via I2C potentiometer (TPL0401B?)
Line 12: Line 13:
 === GPIOA === === GPIOA ===
 ^Pin               ​^Description ​             ^ ^Pin               ​^Description ​             ^
-|0                 ​|Stick RV                 | +|0 (ADC_IN_0) ​     ​|Stick RV                 |
-|1                 ​|Stick RH                 | +|1 (ADC_IN_1) ​     ​|Stick RH                 |
-|2                 ​|Stick LV                 | +|2 (ADC_IN_2) ​     ​|Stick LV                 |
-|3                 ​|Stick LH                 |+|3 (ADC_IN_3) ​     ​|Stick LH                 |
 |4                 ​|Audio Out          | |4                 ​|Audio Out          |
 |5                 ​|Switch B_H                | |5                 ​|Switch B_H                |
-|6                 ​|POT1             |+|6 (ADC_IN_6) ​     ​|AUX5 POT             |
 |7                 |Ext Module TX  | |7                 |Ext Module TX  |
 |8                 ​|Trainer plug detect ​     | |8                 ​|Trainer plug detect ​     |
Line 31: Line 32:
 === GPIOB === === GPIOB ===
-|0               ​|POT2        | +|0 (ADC_IN_8) ​   ​|AUX4 POT        |
-|1               ​|LED ​Blue           |+|1               ​|LED ​Green           |
 |2               ​|S.Port Update PWR                 | |2               ​|S.Port Update PWR                 |
 |3               ​|??? ​          | |3               ​|??? ​          |
Line 41: Line 42:
 |8               ​|Haptic ​      | |8               ​|Haptic ​      |
 |9 (I2C WP)      |EEPROM WP      | |9 (I2C WP)      |EEPROM WP      |
-|10              |Bluetooth Tx            | +|10 (USART_3_TX) ​|Bluetooth Tx            |
-|11              |Bluetooth Rx            |+|11 (USART_3_RX) ​|Bluetooth Rx            |
 |12 (SPI2 CS)    |SD Card Enable ​ | |12 (SPI2 CS)    |SD Card Enable ​ |
 |13 (SPI2 SCK)   |SD Card SCK         | |13 (SPI2 SCK)   |SD Card SCK         |
Line 50: Line 51:
 === GPIOC === === GPIOC ===
 ^Pin            ^Description ​         ^ ^Pin            ^Description ​         ^
-|0              |Voltage detect ​      |+|0 (ADC_IN_10)  ​|Voltage detect ​      |
 |1              |Button 'Trim LHR' ​  | |1              |Button 'Trim LHR' ​  |
-|2              |Buttom ​'Trim RVU' ​  | +|2              |Button ​'Trim RVU' ​  |
-|3              |Buttom ​'Trim RVD' ​  | +|3              |Button ​'Trim RVD' ​  |
-|4              |LED Green      |+|4              |LED Blue      |
 |5              |LED Red      | |5              |LED Red      |
 |6              |Int Module PWR            | |6              |Int Module PWR            |
Line 69: Line 70:
 === GPIOD === === GPIOD ===
-|0    |Power ​button press          | +|0    |Power ​on          |
-|1    |Power ​on  |+|1    |Power ​button press  |
 |2    |Button '​Exit' ​          | |2    |Button '​Exit' ​          |
 |3    |Button '​Page' ​          | |3    |Button '​Page' ​          |
Line 80: Line 81:
 |9    |SD Card Detect ​         | |9    |SD Card Detect ​         |
 |10   ​|??? ​               | |10   ​|??? ​               |
-|11   ​|Switch: ​C_11                 |+|11   ​|Switch: ​C_L                 |
 |12   |LCD RST                 | |12   |LCD RST                 |
 |13   |LCD Backlight ​                 | |13   |LCD Backlight ​                 |
 |14   ​|Switch H                 | |14   ​|Switch H                 |
-|15   |Trim LHL                     |+|15   |Button 'Trim LHL' ​                    |
 === GPIOE === === GPIOE ===
Line 115: Line 116:
 ==== FCC Report ==== ==== FCC Report ====
-FCCID: [[https://www.fcc.gov/general/fcc-id-search-page|XYF X91216DK]]+FCCID: [[https://fccid.io/2ANTI-T12|2ANTI-T12]]
hardware/jumper_t12.1548509750.txt.gz (4598 views) · Last modified: 2019/01/26 05:35 by PhracturedBlue
