hardware:radiolink_at10
hardware:radiolink_at10 [2016/04/20 07:11]
PhracturedBlue created
hardware:radiolink_at10 [2019/02/27 05:25] (current)
csujun add PD6
Line 1: Line 1:
 ===== Radiolink AT10 Hardware Connections ===== ===== Radiolink AT10 Hardware Connections =====
-Coming soon+The following documents the hardware inside the Radiolink AT9 transmitter
-Schematic is available here:+  * MCU[[http://​www.st.com/​web/​catalog/​mmc/​FM141/​SC1169/​SS1031/​LN1565/​PF164491|STM32F103VET6]] 512kB Flash, 64kB RAM 100pin package
 +  * EEPROM: [[http://​www.giantec-semi.com/​upload/​datasheet/​GT24C128A_DS_Adv.pdf|GT24C128A]] 128K-bit I2C SERIAL EEPROM
 +  * LCD Display: FPC-SJ28N-19VOF
 +  * LCD Driver: [[https://​pdf-datasheet-datasheet.netdna-ssl.com/​pdf-down/​S/​T/​7/​ST7796S-Sitronix.pdf|ST7789S]] based 320x480x16bit display
 +  * Radio: CC2533F96 96-KB Flash, 6-KB RAM with RFX2401 driver
 +  * DC/DC converter: MC34063A
 +==== STM32 Connections ====
 +^Pin     ​^Connection ​ ^Description ​          ​^Additional Info^
 +|BOOT0 ​  ​|BOOT0 ​      ​| ​                     |               |
 +=== GPIOA ===
 +|PA00    | CH1        | SRH RIght Hor Stick  | |
 +|PA01    | CH2        | SLV Left Ver Stick   | |
 +|PA02    | CH3        | SRV Right Ver Stick  | |
 +|PA03    | CH4        | SLH Left Hor Stick   | |
 +|PA04    | POT        | Right Shoulder ​   VRE| |
 +|PA05    | POT        | Left Front Dial   VRA| |
 +|PA06    | POT        | Right Front Dial  VRB| |
 +|PA07    | POT        | Center Front Dial VRC| |
 +|PA09    | TX         | Boot connector ​      | |
 +|PA10    | RX         | Boot connector ​      | |
 +|PA11    | BUZZ       | Buzzer ​              | |
 +|PA13    | LED Green  |                      | To cathode through limiting resistor |
 +|PA14    | ENTER      | Menu button ​         | 1K resistor to GND |
 +|PA15    | EXIT       | Menu button ​         | 1K resistor to GND |
 +=== GPIOB ===
 +|PB00    | POT        | Left Shoulder ​    VRD| |
 +|PB01    | LOWBAT ​    | Battery Voltage ​     | |
 +|PB03    | TRL        | Right Trim Left      | |
 +|PB04    | TRR        | Right Trim Right     | |
 +|PB05    | TLU        | Left Trim Up         | |
 +|PB06    | TLD        | Left Trim Down       | |
 +|PB07    | PC OUT     | PCM port             | 4.7K limiting resistor |
 +|PB08    | PC IN      | PCM port             | 4.7K limiting resistor |
 +|PB09    | DISP24 ​    | PWM for LEDs         | Transistor to GND |
 +|PB11    | REST       | RF board             | |
 +|PB12    | CSN        | RF board             | |
 +|PB13    | SCK        | RF board             | |
 +|PB14    | MISO       | RF board             | |
 +|PB15    | MOSI       | RF board             | |
 +=== GPIOC ===
 +|PC00    | K1A        | 2-pos switch ​        ​| ​ |
 +|PC01    | K2B        | 2-pos switch ​        ​| ​ |
 +|PC02    | K3C1       | 3-pos switch ​        ​| ​ |
 +|PC03    | K3C2       | 3-pos switch ​        ​| ​ |  ​
 +|PC04    | K5E1       | 3-pos switch ​        ​| ​ |
 +|PC05    | K5E2       | 3-pos switch ​        ​| ​ |  ​
 +|PC06    | K4D        | 2-pos switch ​        | RC filter |
 +|PC07    | K6F        | 2-pos switch ​        | RC filter |
 +|PC08    | K7G        | 2-pos switch ​        | RC filter |
 +|PC09    | K8H        | 2-pos switch ​        | RC filter |
 +|PC10    | SDA        | EEPROM ​              ​| ​ |
 +|PC11    | SCL        | EEPROM ​              ​| ​ |
 +|PC12    | LED RED    |                      | To cathode through limiting resistor |
 +|PC13    | ENC L      | Rotary Encoder ​      | 10K pull-up |
 +|PC14    | ENC R      | Rotary Encoder ​      | 10K pull-up |
 +|PC15    | ENC Button | Rotary Encoder ​      | Direct to pin |
 +=== GPIOD ===
 +|PD00    | DISP5      | Data                 ​| ​ |    ​
 +|PD01    | DISP6      | Data                 ​| ​ |
 +|PD02    | TRU        | Right Trim Up        |  |
 +|PD03    | TRD        | Right Trim Down      |  |
 +|PD04    | DISP21 ​    | Control ​             |  |
 +|PD05    | DISP22 ​    | Control ​             |  |
 +|PD06    | USB DETECT | Detect USB Plugin ​   |  |
 +|PD07    | DISP20 ​    | Control ​             |  |
 +|PD08    | DISP16 ​    | Data                 ​| ​ |
 +|PD09    | DISP17 ​    | Data                 ​| ​ |
 +|PD10    | DISP18 ​    | Data                 ​| ​ |
 +|PD11    | DISP23 ​    | Control ​             |  |
 +|PD12    | TLL        | Left Trim to Left    |  |
 +|PD13    | TLR        | Left Trim to Right   ​| ​ |
 +|PD14    | DISP3      | Data                 ​| ​ |
 +|PD15    | DISP4      | Data                 ​| ​ |
 +=== GPIOE ===
 +|PE00    | DISP19 ​    | RESx ILI9341 Pin     | Reset is Active low  |
 +|PE01    | POINT1 ​    ​| ​                     |  |
 +|PE02    | POINT2 ​    ​| ​                     |  |
 +|PE03    | POINT3 ​    ​| ​                     |  |
 +|PE04    | POINT4 ​    ​| ​                     |  |
 +|PE05    | POINT6 ​    ​| ​                     |  |
 +|PE06    | POINT10 ​   |                      |  |
 +|PE07    | DISP7      | Data                 ​| ​ |
 +|PE08    | DISP8      | Data                 ​| ​ |
 +|PE09    | DISP9      | Data                 ​| ​ |
 +|PE10    | DISP10 ​    | Data                 ​| ​ |
 +|PE11    | DISP11 ​    | Data                 ​| ​ |
 +|PE12    | DISP12 ​    | Data                 ​| ​ |
 +|PE13    | DISP13 ​    | Data                 ​| ​ |
 +|PE14    | DISP14 ​    | Data                 ​| ​ |
 +|PE15    | DISP15 ​    | Data                 ​| ​ |
 +=== Battery Voltage Measurement ===
 +The battery voltage (ADC1_9) was measured as:
 +^ Voltage ^ ADC Value ^
 +| 15.05V ​ | 0x0FFB ​   |
 +| 10.02V ​ | 0x0A9D ​   |
 +|  4.31V  | 0x048E ​   |
 +is calculated by the formula: ​
 +V = 0.003672 * value + 0.0287
 +=== FCC Report ===
 +FCCID: [[https://​www.fcc.gov/​general/​fcc-id-search-page| U2B RL039AT10]]
 +Schematic is available here (courtesy of FCC):
 {{:​hardware:​at10_schematics.pdf|}} {{:​hardware:​at10_schematics.pdf|}}
hardware/radiolink_at10.1461161471.txt.gz (5023 views) · Last modified: 2016/04/20 07:11 by PhracturedBlue
