hardware:radiolink_at10
hardware:radiolink_at10 [2019/02/07 17:03]
csujun initial version copy form at9
hardware:radiolink_at10 [2019/02/27 05:25] (current)
csujun add PD6
Line 5: Line 5:
   * EEPROM: [[http://​www.giantec-semi.com/​upload/​datasheet/​GT24C128A_DS_Adv.pdf|GT24C128A]] 128K-bit I2C SERIAL EEPROM   * EEPROM: [[http://​www.giantec-semi.com/​upload/​datasheet/​GT24C128A_DS_Adv.pdf|GT24C128A]] 128K-bit I2C SERIAL EEPROM
   * LCD Display: FPC-SJ28N-19VOF   * LCD Display: FPC-SJ28N-19VOF
-  * LCD Driver: ​ILI9341 ​based 320x240x16bit ​display+  * LCD Driver: ​[[https://​pdf-datasheet-datasheet.netdna-ssl.com/​pdf-down/​S/​T/​7/​ST7796S-Sitronix.pdf|ST7789S]] ​based 320x480x16bit ​display
   * Radio: CC2533F96 96-KB Flash, 6-KB RAM with RFX2401 driver   * Radio: CC2533F96 96-KB Flash, 6-KB RAM with RFX2401 driver
   * DC/DC converter: MC34063A   * DC/DC converter: MC34063A
Line 19: Line 19:
 |PA02    | CH3        | SRV Right Ver Stick  | | |PA02    | CH3        | SRV Right Ver Stick  | |
 |PA03    | CH4        | SLH Left Hor Stick   | | |PA03    | CH4        | SLH Left Hor Stick   | |
-|PA04    | POT        | Right Shoulder ​      ​| | +|PA04    | POT        | Right Shoulder ​   VRE| |
-|PA05    | POT        | Left Front Dial      | | +|PA05    | POT        | Left Front Dial   VRA| |
-|PA06    | POT        | Right Front Dial     ​| | +|PA06    | POT        | Right Front Dial  VRB| |
-|PA08    ​| ​K8H        ​| ​2-pos switch ​        RC filter ​|+|PA07    ​| ​POT        ​| ​Center Front Dial VRC| |
 |PA09    | TX         | Boot connector ​      | | |PA09    | TX         | Boot connector ​      | |
 |PA10    | RX         | Boot connector ​      | | |PA10    | RX         | Boot connector ​      | |
 +|PA11    | BUZZ       | Buzzer ​              | |
 |PA13    | LED Green  |                      | To cathode through limiting resistor | |PA13    | LED Green  |                      | To cathode through limiting resistor |
 |PA14    | ENTER      | Menu button ​         | 1K resistor to GND | |PA14    | ENTER      | Menu button ​         | 1K resistor to GND |
Line 31: Line 32:
 === GPIOB === === GPIOB ===
 ^Pin     ​^Connection ​ ^Description ​          ​^Additional Info^ ^Pin     ​^Connection ​ ^Description ​          ​^Additional Info^
-|PB00    | POT        | Left Shoulder ​       | |+|PB00    | POT        | Left Shoulder ​    VRD| |
 |PB01    | LOWBAT ​    | Battery Voltage ​     | | |PB01    | LOWBAT ​    | Battery Voltage ​     | |
 |PB03    | TRL        | Right Trim Left      | | |PB03    | TRL        | Right Trim Left      | |
Line 56: Line 57:
 |PC06    | K4D        | 2-pos switch ​        | RC filter | |PC06    | K4D        | 2-pos switch ​        | RC filter |
 |PC07    | K6F        | 2-pos switch ​        | RC filter | |PC07    | K6F        | 2-pos switch ​        | RC filter |
-|PC08    | K7G1       3-pos switch ​        | RC filter | +|PC08    | K7G        ​2-pos switch ​        | RC filter |
-|PC09    | K7G2       3-pos switch ​        | RC filter |+|PC09    | K8H        ​2-pos switch ​        | RC filter |
 |PC10    | SDA        | EEPROM ​              ​| ​ |  |PC10    | SDA        | EEPROM ​              ​| ​ |
 |PC11    | SCL        | EEPROM ​              ​| ​ |    |PC11    | SCL        | EEPROM ​              ​| ​ |
-|PC12    | VIBRATOR ​  |                      | Transistor ​|+|PC12    | LED RED    ​|                      | To cathode through limiting resistor ​|
 |PC13    | ENC L      | Rotary Encoder ​      | 10K pull-up | |PC13    | ENC L      | Rotary Encoder ​      | 10K pull-up |
 |PC14    | ENC R      | Rotary Encoder ​      | 10K pull-up | |PC14    | ENC R      | Rotary Encoder ​      | 10K pull-up |
Line 73: Line 74:
 |PD04    | DISP21 ​    | Control ​             |  | |PD04    | DISP21 ​    | Control ​             |  |
 |PD05    | DISP22 ​    | Control ​             |  | |PD05    | DISP22 ​    | Control ​             |  |
 +|PD06    | USB DETECT | Detect USB Plugin ​   |  |
 |PD07    | DISP20 ​    | Control ​             |  | |PD07    | DISP20 ​    | Control ​             |  |
 |PD08    | DISP16 ​    | Data                 ​| ​ | |PD08    | DISP16 ​    | Data                 ​| ​ |
Line 86: Line 88:
 |PE00    | DISP19 ​    | RESx ILI9341 Pin     | Reset is Active low  | |PE00    | DISP19 ​    | RESx ILI9341 Pin     | Reset is Active low  |
-|PE01    | LED Red    ​|                      | To cathode through limiting resistor ​+|PE01    | POINT1 ​    |                      |  |
-|PE02    | BUZZER ​    |                      | Transistor ​+|PE02    | POINT2 ​    |                      |  |
 +|PE03    | POINT3 ​    ​| ​                     |  |
 +|PE04    | POINT4 ​    ​| ​                     |  |
 +|PE05    | POINT6 ​    ​| ​                     |  |
 +|PE06    | POINT10 ​   |                      |  ​
 |PE07    | DISP7      | Data                 ​| ​ |    |PE07    | DISP7      | Data                 ​| ​ |
 |PE08    | DISP8      | Data                 ​| ​ | |PE08    | DISP8      | Data                 ​| ​ |
hardware/radiolink_at10.1549587802.txt.gz (5064 views) · Last modified: 2019/02/07 17:03 by csujun
