hardware:radiolink_at10
hardware:radiolink_at10 [2019/02/08 00:20] csujun |
hardware:radiolink_at10 [2019/02/27 05:25] (current) csujun add PD6 |
| Line 5: | Line 5: | ||
| * EEPROM: [[http://www.giantec-semi.com/upload/datasheet/GT24C128A_DS_Adv.pdf|GT24C128A]] 128K-bit I2C SERIAL EEPROM | * EEPROM: [[http://www.giantec-semi.com/upload/datasheet/GT24C128A_DS_Adv.pdf|GT24C128A]] 128K-bit I2C SERIAL EEPROM | ||
| * LCD Display: FPC-SJ28N-19VOF | * LCD Display: FPC-SJ28N-19VOF | ||
| - | * LCD Driver: ILI9341 based 320x240x16bit display | + | * LCD Driver: [[https://pdf-datasheet-datasheet.netdna-ssl.com/pdf-down/S/T/7/ST7796S-Sitronix.pdf|ST7789S]] based 320x480x16bit display |
| * Radio: CC2533F96 96-KB Flash, 6-KB RAM with RFX2401 driver | * Radio: CC2533F96 96-KB Flash, 6-KB RAM with RFX2401 driver | ||
| * DC/DC converter: MC34063A | * DC/DC converter: MC34063A | ||
| Line 19: | Line 19: | ||
| |PA02 | CH3 | SRV Right Ver Stick | | | |PA02 | CH3 | SRV Right Ver Stick | | | ||
| |PA03 | CH4 | SLH Left Hor Stick | | | |PA03 | CH4 | SLH Left Hor Stick | | | ||
| - | |PA04 | POT | Right Shoulder | | | + | |PA04 | POT | Right Shoulder VRE| | |
| - | |PA05 | POT | Left Front Dial | | | + | |PA05 | POT | Left Front Dial VRA| | |
| - | |PA06 | POT | Right Front Dial | | | + | |PA06 | POT | Right Front Dial VRB| | |
| - | |PA08 | K8H | 2-pos switch | RC filter | | + | |PA07 | POT | Center Front Dial VRC| | |
| |PA09 | TX | Boot connector | | | |PA09 | TX | Boot connector | | | ||
| |PA10 | RX | Boot connector | | | |PA10 | RX | Boot connector | | | ||
| |PA11 | BUZZ | Buzzer | | | |PA11 | BUZZ | Buzzer | | | ||
| - | |PA12 | LED RED | | To cathode through limiting resistor | | ||
| |PA13 | LED Green | | To cathode through limiting resistor | | |PA13 | LED Green | | To cathode through limiting resistor | | ||
| |PA14 | ENTER | Menu button | 1K resistor to GND | | |PA14 | ENTER | Menu button | 1K resistor to GND | | ||
| Line 33: | Line 32: | ||
| ^Pin ^Connection ^Description ^Additional Info^ | ^Pin ^Connection ^Description ^Additional Info^ | ||
| - | |PB00 | POT | Left Shoulder | | | + | |PB00 | POT | Left Shoulder VRD| | |
| |PB01 | LOWBAT | Battery Voltage | | | |PB01 | LOWBAT | Battery Voltage | | | ||
| |PB03 | TRL | Right Trim Left | | | |PB03 | TRL | Right Trim Left | | | ||
| Line 58: | Line 57: | ||
| |PC06 | K4D | 2-pos switch | RC filter | | |PC06 | K4D | 2-pos switch | RC filter | | ||
| |PC07 | K6F | 2-pos switch | RC filter | | |PC07 | K6F | 2-pos switch | RC filter | | ||
| - | |PC08 | K7G1 | 3-pos switch | RC filter | | + | |PC08 | K7G | 2-pos switch | RC filter | |
| - | |PC09 | K7G2 | 3-pos switch | RC filter | | + | |PC09 | K8H | 2-pos switch | RC filter | |
| |PC10 | SDA | EEPROM | | | |PC10 | SDA | EEPROM | | | ||
| |PC11 | SCL | EEPROM | | | |PC11 | SCL | EEPROM | | | ||
| - | |PC12 | VIBRATOR | | Transistor | | + | |PC12 | LED RED | | To cathode through limiting resistor | |
| |PC13 | ENC L | Rotary Encoder | 10K pull-up | | |PC13 | ENC L | Rotary Encoder | 10K pull-up | | ||
| |PC14 | ENC R | Rotary Encoder | 10K pull-up | | |PC14 | ENC R | Rotary Encoder | 10K pull-up | | ||
| Line 75: | Line 74: | ||
| |PD04 | DISP21 | Control | | | |PD04 | DISP21 | Control | | | ||
| |PD05 | DISP22 | Control | | | |PD05 | DISP22 | Control | | | ||
| + | |PD06 | USB DETECT | Detect USB Plugin | | | ||
| |PD07 | DISP20 | Control | | | |PD07 | DISP20 | Control | | | ||
| |PD08 | DISP16 | Data | | | |PD08 | DISP16 | Data | | | ||
| Line 88: | Line 88: | ||
| |PE00 | DISP19 | RESx ILI9341 Pin | Reset is Active low | | |PE00 | DISP19 | RESx ILI9341 Pin | Reset is Active low | | ||
| - | |PE01-06 | POINT | | test point | | + | |PE01 | POINT1 | | | |
| + | |PE02 | POINT2 | | | | ||
| + | |PE03 | POINT3 | | | | ||
| + | |PE04 | POINT4 | | | | ||
| + | |PE05 | POINT6 | | | | ||
| + | |PE06 | POINT10 | | | | ||
| |PE07 | DISP7 | Data | | | |PE07 | DISP7 | Data | | | ||
| |PE08 | DISP8 | Data | | | |PE08 | DISP8 | Data | | | ||
hardware/radiolink_at10.1549614032.txt.gz (5067 views) · Last modified: 2019/02/08 00:20 by csujun
