hardware:taranis_x9d
hardware:taranis_x9d [2016/04/15 18:50]
PhracturedBlue created
hardware:taranis_x9d [2016/04/20 07:33] (current)
PhracturedBlue
Line 1: Line 1:
 +~~TOC:3-4~~
 ===== Taranis X9D Hardware Connections ===== ===== Taranis X9D Hardware Connections =====
 The following documents the hardware inside the Taranis X9D transmitter The following documents the hardware inside the Taranis X9D transmitter
Line 9: Line 10:
 === GPIOA === === GPIOA ===
-^Pin    ^Description ​        ​+^Pin               ​^Description ​
-| 0 |  Stick RV | +|0                 ​|Stick RV                 ​
-| 1 |  Stick RH | +|1                 ​|Stick RH                 ​
-| 2 |  Stick LH | +|2                 ​|Stick LH                 ​
-| 3 |  Stick LV | +|3                 ​|Stick LV                 ​
-| 4 |  Audio DAC (???) | +|4                 ​|Audio DAC (???)
-| 5 |  Switch C- | +|5                 ​|Switch C-
-| 6 |  POT L (Aux2) | +|6                 ​|POT L (Aux2) ​            ​
-| 7 |  PPM for external module | +|7                 ​|PPM for external module ​
-| 8 |  Trainer plug detect | +|8                 ​|Trainer plug detect ​
-| 9 |  USB Vin | +|9                 ​|USB Vin
-| 10 |  PPM for FrSky Module | +|10                |PPM for FrSky Module ​    ​
-| 11 |  USB Data- | +|11                |USB Data-
-| 12 |  USB Data+ | +|12                |USB Data+
-| 13 |  SWDIO (Pads on P12.2) | +|13                |SWDIO (Pads on P12.2) ​
-| 14 |  SWCLK (Pads on P12.3) | +|14                |SWCLK (Pads on P12.3) ​
-| 15 (SPI3 Enable) ​ I2S Audio WS (???) |+|15 (SPI3 Enable)  ​|I2S Audio WS (???)       ​|
 === GPIOB === === GPIOB ===
-^Pin    ^Description ​        ^ +^Pin             ​^Description ​        ^
-| 0 |  POT R (Aux3) | +|0               ​|POT R (Aux3) ​
-| 1 |  Switch D- | +|1               ​|Switch D-           ​
-| 2 |  ??? | +|2               ​|???                 ​
-| 3 |  Switch E- | +|3               ​|Switch E-           ​
-| 4 |  Switch E+ | +|4               ​|Switch E+           ​
-| 5 |  Switch A+ | +|5               ​|Switch A+           ​
-| 6 (I2C SCL) |  EEPROM SCL(???) | +|6 (I2C SCL)     ​|EEPROM SCL(???​) ​    ​
-| 7 (I2C SDA) |  EEPROM SDA(???) | +|7 (I2C SDA)     ​|EEPROM SDA(???​) ​    ​
-| 8 |  Backlight PWM | +|8               ​|Backlight PWM       ​
-| 9 (I2C WP) |  EEPROM WP(???) | +|9 (I2C WP)      |EEPROM WP(???​) ​
-| 10 |  UART3 Tx | +|10              |UART3 Tx
-| 11 |  UART3 Rx | +|11              |UART3 Rx
-| 12 (SPI2 CS) |  SD Card ChipSelect | +|12 (SPI2 CS)    |SD Card ChipSelect ​
-| 13 (SPI2 SCK) |  SD Card SCK | +|13 (SPI2 SCK)   ​|SD Card SCK         ​
-| 14 (SPI2 MISO)  SD Card MISO | +|14 (SPI2 MISO)  ​|SD Card MISO
-| 15 (SPI2 MOSI)  SD Card MOSI |+|15 (SPI2 MOSI)  ​|SD Card MOSI        |
 === GPIOC === === GPIOC ===
-^Pin    ^Description ​        ​+^Pin            ^Description ​
-| 0 |  Voltage detect | +|0              |Voltage detect ​      ​
-| 1 |  Buttom 'Trim RH -' | +|1              |Buttom 'Trim RH -' ​  ​
-| 2 |  Buttom 'Trim RV +' | +|2              |Buttom 'Trim RV +' ​  ​
-| 3 |  Buttom 'Trim RV -' | +|3              |Buttom 'Trim RV -' ​  ​
-| 4 |  Slider L (Aux4) | +|4              |Slider L (Aux4) ​
-| 5 |  Slider R (Aux5) | +|5              |Slider R (Aux5) ​
-| 6 |  Power LED | +|6              |Power LED
-| 7 |  Heartbeat (???) | +|7              |Heartbeat (???)
-| 8 |  Trainer PPM In | +|8              |Trainer PPM In       ​
-| 9 |  Trainer PPM Out | +|9              |Trainer PPM Out
-| 10 (SPI3 SCK)  ​I2S_Audio SCK(???) | +|10 (SPI3 SCK)  ​|I2S_Audio SCK(???​) ​  ​
-| 11 | Audio DAC Mute(???) | +|11             ​|Audio DAC Mute(???​) ​
-| 12 (SPI3 SD) |  I2S_Audio SD(???) | +|12 (SPI3 SD)   ​|I2S_Audio SD(???​) ​
-| 13 |  Buttom 'Trim RH +' | +|13             ​|Buttom 'Trim RH +' ​  ​
-| 14 |  XTAL | +|14             ​|XTAL                 ​
-| 15 |  XTAL |+|15             ​|XTAL                 ​|
 === GPIOD === === GPIOD ===
-^Pin    ^Description ​        ​+^Pin  ^Description ​            ​
-| 0 |  Power shutdown | +|0    |Power shutdown ​
-| 1 |  Power switch postition | +|1    |Power switch postition ​
-| 2 |  Button '​Exit'​ | +|2    |Button '​Exit' ​          ​
-| 3 |  Button '​Page'​ | +|3    |Button '​Page' ​          ​
-| 4 |  Sport Enable(???) | +|4    |Sport Enable(???​) ​      ​
-| 5 |  Sport Tx(???) | +|5    |Sport Tx(???​) ​          ​
-| 6 |  Sport Rx(???) | +|6    |Sport Rx(???​) ​          ​
-| 7 |  Button '​Menu'​ | +|7    |Button '​Menu' ​          ​
-| 8 |  ??? | +|8    |???                     ​
-| 9 |  SD Card Detect | +|9    |SD Card Detect ​
-| 10 |  LCD MOSI | +|10   ​|LCD MOSI
-| 11 |  LCD CLK | +|11   ​|LCD CLK                 ​
-| 12 |  LCD RST | +|12   ​|LCD RST                 ​
-| 13 |  LCD A0 | +|13   ​|LCD A0
-| 14 |  LCD NCS | +|14   ​|LCD NCS                 ​
-| 15 |  N/C |+|15   ​|N/C                     ​|
 === GPIOE === === GPIOE ===
-^Pin    ^Description ​        ^ +^Pin  ^Description ​        ^
-| 0 |  Switch A- | +|0    |Switch A-           ​
-| 1 |  Switch B+ | +|1    |Switch B+           ​
-| 2 |  Switch B- | +|2    |Switch B-           ​
-| 3 |  Button 'Trim LH +' | +|3    |Button 'Trim LH +' ​
-| 4 |  Button 'Trim LH -' | +|4    |Button 'Trim LH -' ​
-| 5 |  Button 'Trim LV +' | +|5    |Button 'Trim LV +' ​
-| 6 |  Button 'Trim LV -' | +|6    |Button 'Trim LV -' ​
-| 7 |  Switch D+ | +|7    |Switch D+           ​
-| 8 |  Switch G- | +|8    |Switch G-           ​
-| 9 |  Switch G+ | +|9    |Switch G+           ​
-| 10 |  Button '​Plus'​ | +|10   ​|Button '​Plus' ​      ​
-| 11 |  Button '​Enter'​ | +|11   ​|Button '​Enter' ​
-| 12 |  Button '​Minus'​ | +|12   ​|Button '​Minus' ​
-| 13 |  Switch H | +|13   ​|Switch H
-| 14 |  Switch F | +|14   ​|Switch F
-| 15 |  Switch C+ |+|15   ​|Switch C+           ​|
 ==== Pad P12 ==== ==== Pad P12 ====
-| 1 |  3.3V | +|1    |3.3V         ​
-| 2 |  PA13 | +|2    |PA13         ​
-| 3 |  PA14 | +|3    |PA14         ​
-| 4 |  GND |+|4    |GND          |
 ==== Externaml PPM Module (Pin 1 at bottom) ==== ==== Externaml PPM Module (Pin 1 at bottom) ====
-| 1 |  SPORT | +|1    |SPORT ​
-| 2 |  GND | +|2    |GND
-| 3 |  ??? | +|3    |???
-| 4 |  Heartbeat | +|4    |Heartbeat ​
-| 5 |  ??? |+|5    |???          |
 +==== FCC Report ====
 +FCCID: [[https://​www.fcc.gov/​general/​fcc-id-search-page|XYF X91216DK]]
hardware/taranis_x9d.1460771407.txt.gz (14352 views) · Last modified: 2016/04/15 18:50 by PhracturedBlue
