release_notes:4.0.0
release_notes:4.0.0 [2016/04/27 06:59]
PhracturedBlue created
release_notes:4.0.0 [2017/01/23 00:43] (current)
FDR https
Line 27: Line 27:
   * The channel scale is applied after the safety value. ​ If safety is in use, make sure to check the values   * The channel scale is applied after the safety value. ​ If safety is in use, make sure to check the values
   * The toggle icon locations have changed. ​ Generally all models will need to be reconfigured to use the new icons. ​ This was unintentional,​ but not easily rectified at this point.   * The toggle icon locations have changed. ​ Generally all models will need to be reconfigured to use the new icons. ​ This was unintentional,​ but not easily rectified at this point.
-  * If upgrading from a previous Deviation release and using an A7105 module (Flysky/​Hubsan),​ the module will be initially disabled until you follow the directions here: http://​www.deviationtx.com/​forum/​6-general-discussions/​1572-flysky-module-users-you-need-to-read-this+  * If upgrading from a previous Deviation release and using an A7105 module (Flysky/​Hubsan),​ the module will be initially disabled until you follow the directions here: https://​www.deviationtx.com/​forum/​6-general-discussions/​1572-flysky-module-users-you-need-to-read-this
release_notes/4.0.0.1461765570.txt.gz (194502 views) · Last modified: 2016/04/27 06:59 by PhracturedBlue
