release_notes:5.0.0
release_notes:5.0.0 [2016/04/27 06:16]
PhracturedBlue
release_notes:5.0.0 [2017/05/17 08:03] (current)
Texacate added the date 5.0.0 was released
Line 1: Line 1:
 ===== Version 5.0.0 ===== ===== Version 5.0.0 =====
-** NOTE: Deviation ​5.0.0 has not been released ​yet.  There release notes are a work-in progress**+Version ​5.0.0 was released ​on 2016-04-30
-**IMPORTANT:​ You must install the filesystem along with the new firmware. ​ Make sure to save your models first!**+**IMPORTANT:​**\\
 +**You must install the filesystem along with the new firmware. ​ Make sure to save your models first!**\\
 +**The configuration of hardware mods has changed since the previous 4.0.1 version. Instead of the tx.ini, they are in a new hardware.ini file, just like they were in the last nightly builds.**
 ==== Installation ==== ==== Installation ====
-  * Follow the instructions in the [[ http://​www.deviationtx.com/​user-manual | User Manual ]] that applies to your transmitter+  * Follow the instructions in the [[ https://​www.deviationtx.com/​user-manual | User Manual ]] that applies to your transmitter
 +==== Critical bug fixes ====
 +  * DSM2/DSMX fixes for lost binding during operation
 ==== Major Features ==== ==== Major Features ====
 +  * Allow reordering mixers on Devo7e/10
 +  * Reworked telemetry to have different displays for different protocols
 +  * Add Range Test capability
 +  * Support permanent timers
 +==== Minor Features / Bug Fixes ====
 +  * Support hardware modification to add extra switches to the devo7e
 +  * Support hardware modification to add vibration for Devo6/8
 +  * Add support for multi-module
 +  * Automatically reorder channels when changing protocols
 +  * Support smaller fonts in Devo7e
 +  * Improve volume control
 +  * Fix telemetry alarms
 +  * Fix power output contol for CC2500 protocols
 +  * Fix date displays
 +  * Support 4 alarm sounds for timers
 +  * Improve scrolling on many of the GUI screens
 +  * Support viewing virtual channels on Channel-test page
 +  * Telemetry alarms are more prominent
 +  * Properly display PPMIN on main page
 +  * Add debug log display option
 +  * Support newer Devo12S (with Rev2 Epson LCD driver)
 +  * Fix channel mapping when loading templates
 +  * Remove hardcoded fonts to improve theme-ability
 +  * Protocol fixes
 +      * YD717 - Fix channels for rudder, aileron, elevator
 +      * YD717 - Use random channels to allow multiple vehicles to fly in the same area
 +      * YD717 - Enable high-rate mode
 +      * YD717 - Support receiver throttle saftey
 +      * YD717 - Don't hang the transmitter waiting for a response from the model
 +      * Properly handle Tx mode in Hubsan protocol
 +      * DSM2/X - telemetry display fixes. ​ Support temperature display
 +      * DSM2/X - support extended telemetry info
 +      * DSM2/X - fix GPS heading units
 +      * DSM2/X - RSSI in dBM
 +      * WK* - Show dialog until biding is complete
 +      * USBHID - Support up to 12 channels
 +      * V202 - Support bind on power-up
 +      * PPMOUT - Allow more than 10 channels
 +      * V202 - Add 250kbps mode, headless, and calibration
 +      * HiSky - Support 3/6 axis option
 +      * Devo - Fix loss of signal issue with telemetry enabled
 +      * Flysky - Update packet period to increase compatibilty with more receivers
-==== Minor Features ​==== +==== New protocols ​====
- +      * SymaX
-==== Critical bug fixes ====+      * Frsky 2-way and V8 protocols
 +      * YD717 now supports Sky Walker 1306
 +      * YD717 supports XinXun
 +      * Crazyflie '​CFlie'​ protocol
 +      * H377 protocol
 +      * HM380 protocol
 +      * KN (V977) protocol
 +      * ESky150 protocol
 +      * Bluefly HP100
 +      * Flysky supports WLToys V6x6, v919, v913 v915
 +      * CX10 protocol
 +      * CG023 protocol - supports EAchine CG023 / 3D X4 / Attop YD-829(C)
 +      * Joysway protocol
 +      * Hontai protocol
 +      * MT99 protocol - Supports Eachine H7
 +      * FY326 protocol
 +      * Bayang protocol - Supports H8 model and others
 +      * MJXq protocol
 +      * H8_3d protocol
 +      * Futaba S-FHSS protocol
release_notes/5.0.0.1461762965.txt.gz (39239 views) · Last modified: 2016/04/27 06:16 by PhracturedBlue
