release_notes:5.0.0
release_notes:5.0.0 [2016/04/30 10:47]
PhracturedBlue
release_notes:5.0.0 [2017/05/17 08:03] (current)
Texacate added the date 5.0.0 was released
Line 1: Line 1:
-===== Version 5.0.0 (Unreleased) ​===== +===== Version 5.0.0 =====
-** NOTE: Deviation ​5.0.0 has not been released ​yet.  There release notes are a work-in progress**+Version ​5.0.0 was released ​on 2016-04-30
-**IMPORTANT:​ You must install the filesystem along with the new firmware. ​ Make sure to save your models first!**+**IMPORTANT:​**\\
 +**You must install the filesystem along with the new firmware. ​ Make sure to save your models first!**\\
 +**The configuration of hardware mods has changed since the previous 4.0.1 version. Instead of the tx.ini, they are in a new hardware.ini file, just like they were in the last nightly builds.**
 ==== Installation ==== ==== Installation ====
-  * Follow the instructions in the [[ http://​www.deviationtx.com/​user-manual | User Manual ]] that applies to your transmitter+  * Follow the instructions in the [[ https://​www.deviationtx.com/​user-manual | User Manual ]] that applies to your transmitter
 ==== Critical bug fixes ==== ==== Critical bug fixes ====
Line 29: Line 31:
   * Improve scrolling on many of the GUI screens   * Improve scrolling on many of the GUI screens
   * Support viewing virtual channels on Channel-test page   * Support viewing virtual channels on Channel-test page
-  * Telemetry ​alars are moe prominent+  * Telemetry ​alarms ​are more prominent
   * Properly display PPMIN on main page   * Properly display PPMIN on main page
   * Add debug log display option   * Add debug log display option
   * Support newer Devo12S (with Rev2 Epson LCD driver)   * Support newer Devo12S (with Rev2 Epson LCD driver)
   * Fix channel mapping when loading templates   * Fix channel mapping when loading templates
-  * Remove hardcoded fonts to improve ​themability+  * Remove hardcoded fonts to improve ​theme-ability
   * Protocol fixes   * Protocol fixes
       * YD717 - Fix channels for rudder, aileron, elevator       * YD717 - Fix channels for rudder, aileron, elevator
Line 40: Line 42:
       * YD717 - Enable high-rate mode       * YD717 - Enable high-rate mode
       * YD717 - Support receiver throttle saftey       * YD717 - Support receiver throttle saftey
-      * YD717 - Don'​t ​hange the transmitter waiting ​fro a response from the model+      * YD717 - Don'​t ​hang the transmitter waiting ​for a response from the model
       * Properly handle Tx mode in Hubsan protocol       * Properly handle Tx mode in Hubsan protocol
       * DSM2/X - telemetry display fixes. ​ Support temperature display       * DSM2/X - telemetry display fixes. ​ Support temperature display
Line 76: Line 78:
       * MJXq protocol       * MJXq protocol
       * H8_3d protocol       * H8_3d protocol
 +      * Futaba S-FHSS protocol
release_notes/5.0.0.1462038421.txt.gz (39221 views) · Last modified: 2016/04/30 10:47 by PhracturedBlue
