release_notes:5.0.0
release_notes:5.0.0 [2016/04/30 12:56] Arnold [Minor Features / Bug Fixes] |
| Line 1: | Line 1: | ||
| - | ===== Version 5.0.0 (Unreleased) ===== | + | ===== Version 5.0.0 ===== |
| - | ** NOTE: Deviation 5.0.0 has not been released yet. These release notes are a work-in progress** | + | Version 5.0.0 was released on 2016-04-30 |
| - | **IMPORTANT: You must install the filesystem along with the new firmware. Make sure to save your models first!** | + | **IMPORTANT:**\\ |
| + | **You must install the filesystem along with the new firmware. Make sure to save your models first!**\\ | ||
| + | **The configuration of hardware mods has changed since the previous 4.0.1 version. Instead of the tx.ini, they are in a new hardware.ini file, just like they were in the last nightly builds.** | ||
| ==== Installation ==== | ==== Installation ==== | ||
| - | * Follow the instructions in the [[ http://www.deviationtx.com/user-manual | User Manual ]] that applies to your transmitter | + | * Follow the instructions in the [[ https://www.deviationtx.com/user-manual | User Manual ]] that applies to your transmitter |
| ==== Critical bug fixes ==== | ==== Critical bug fixes ==== | ||
| Line 34: | Line 36: | ||
| * Support newer Devo12S (with Rev2 Epson LCD driver) | * Support newer Devo12S (with Rev2 Epson LCD driver) | ||
| * Fix channel mapping when loading templates | * Fix channel mapping when loading templates | ||
| - | * Remove hardcoded fonts to improve themability | + | * Remove hardcoded fonts to improve theme-ability |
| * Protocol fixes | * Protocol fixes | ||
| * YD717 - Fix channels for rudder, aileron, elevator | * YD717 - Fix channels for rudder, aileron, elevator | ||
| Line 40: | Line 42: | ||
| * YD717 - Enable high-rate mode | * YD717 - Enable high-rate mode | ||
| * YD717 - Support receiver throttle saftey | * YD717 - Support receiver throttle saftey | ||
| - | * YD717 - Don't hange the transmitter waiting fro a response from the model | + | * YD717 - Don't hang the transmitter waiting for a response from the model |
| * Properly handle Tx mode in Hubsan protocol | * Properly handle Tx mode in Hubsan protocol | ||
| * DSM2/X - telemetry display fixes. Support temperature display | * DSM2/X - telemetry display fixes. Support temperature display | ||
| Line 76: | Line 78: | ||
| * MJXq protocol | * MJXq protocol | ||
| * H8_3d protocol | * H8_3d protocol | ||
| + | * Futaba S-FHSS protocol | ||
release_notes/5.0.0.1462046194.txt.gz (39227 views) · Last modified: 2016/04/30 12:56 by Arnold
