release_notes:5.0.0
release_notes:5.0.0 [2016/04/30 13:00] Arnold [Version 5.0.0 (Unreleased)] |
| Line 1: | Line 1: | ||
| - | ===== Version 5.0.0 (Unreleased) ===== | + | ===== Version 5.0.0 ===== |
| - | ** NOTE: Deviation 5.0.0 has not been released yet. These release notes are a work-in-progress** | + | Version 5.0.0 was released on 2016-04-30 |
| - | **IMPORTANT: You must install the filesystem along with the new firmware. Make sure to save your models first!** | + | **IMPORTANT:**\\ |
| + | **You must install the filesystem along with the new firmware. Make sure to save your models first!**\\ | ||
| + | **The configuration of hardware mods has changed since the previous 4.0.1 version. Instead of the tx.ini, they are in a new hardware.ini file, just like they were in the last nightly builds.** | ||
| ==== Installation ==== | ==== Installation ==== | ||
| - | * Follow the instructions in the [[ http://www.deviationtx.com/user-manual | User Manual ]] that applies to your transmitter | + | * Follow the instructions in the [[ https://www.deviationtx.com/user-manual | User Manual ]] that applies to your transmitter |
| ==== Critical bug fixes ==== | ==== Critical bug fixes ==== | ||
| Line 40: | Line 42: | ||
| * YD717 - Enable high-rate mode | * YD717 - Enable high-rate mode | ||
| * YD717 - Support receiver throttle saftey | * YD717 - Support receiver throttle saftey | ||
| - | * YD717 - Don't hange the transmitter waiting fro a response from the model | + | * YD717 - Don't hang the transmitter waiting for a response from the model |
| * Properly handle Tx mode in Hubsan protocol | * Properly handle Tx mode in Hubsan protocol | ||
| * DSM2/X - telemetry display fixes. Support temperature display | * DSM2/X - telemetry display fixes. Support temperature display | ||
| Line 76: | Line 78: | ||
| * MJXq protocol | * MJXq protocol | ||
| * H8_3d protocol | * H8_3d protocol | ||
| + | * Futaba S-FHSS protocol | ||
release_notes/5.0.0.1462046458.txt.gz (39226 views) · Last modified: 2016/04/30 13:00 by Arnold
