transmiterswitches
transmiterswitches [2016/04/15 08:38]
FDR [Switches available]
transmiterswitches [2017/05/21 12:03] (current)
mwm
Line 1: Line 1:
 ===== Devo transmitter switches ===== ===== Devo transmitter switches =====
-The one serious issue when porting model files is that the new model may not have the same set of switces ​as the old one. In order to help people wanting to port a model file to a model they don't have, I've provided a list of switches here, listing the tx's in numerical order.+The one serious issue when porting model files is that the new transmitter ​may not have the same set of switches ​as the old one. In order to help people wanting to port a model file fram a transmitter ​they don't have, I've provided a list of switches here, listing the tx's in numerical order.
 ==== Switches available ==== ==== Switches available ====
   * **Devo6**:   * **Devo6**:
      * **Stock**: \\ DR0, DR1, GEAR0, GEAR1, MIX0, MIX1, MIX2, FMOD0, FMOD1, FMOD2      * **Stock**: \\ DR0, DR1, GEAR0, GEAR1, MIX0, MIX1, MIX2, FMOD0, FMOD1, FMOD2
-     * **Modded**((There are published hardware mods for the 6 and 6s to add either two 2-way switches or a 3-way switch just by connecting the switches to the existing through holes. These are supported ​by the latest nightly builds)): \\ SW A0, SW A1, SW A2, SW B0, SW B1+     * **Modded**((There are [[http://​www.rcgroups.com/​forums/​showthread.php?​t=2536181|published hardware mods]] for the 6 and 6s to add either two 2-way switches or a 3-way switch just by connecting the switches to the existing through holes. Additionally two pairs of Trims can be added using existing through holes. These are supported ​in 5.0 and later. ​ Adding both switches and trims brings the number of inputs on the 6/6S to the same level as the 8/​8S/​10/​F12E)): \\ (SW A0, SW A1, SW A2) or (SW A0, SW A1, SW B0, SW B1)
   * **Devo7e**:   * **Devo7e**:
      * **Stock**: \\ HOLD0, HOLD1, FMOD0, FMOD1      * **Stock**: \\ HOLD0, HOLD1, FMOD0, FMOD1
-     * **Modded**((There are published hardware ​modes for the 7e to add two 2-way switches or a 3-way switch by just adding the connections. A more complicated mod makes it possible to add two three-way switches. These are supported ​by the latest nightly builds)): \\ SW A0, SW A1, SW A2, SW B0, SW B1, SW B2+     * **Modded**((There are [[https://​www.deviationtx.com/​forum/​how-to/​1436-add-two-switches-to-the-devo-7e?​start=180|published hardware ​mods]] ​for the 7e to add two 2-way switches or a 3-way switch by just adding the connections. A more complicated mod makes it possible to add two three-way switches. These are supported ​in 5.0 and later)): \\ SW A0, SW A1, SW A2, SW B0, SW B1, SW B2
-  *  **Devo8** and **Devo10** and **Devo F12E**: \\ RUD DR0, RUD DR1, ELE DR0, ELE DR1, AIL DR0, AIL DR1, GEAR0, GEAR1, MIX0, MIX1, MIX2, FMOD0, FMOD1, FMOD2+  *  **Devo8** and **Devo10** and **Devo F12E**:
 +     * **Stock**: \\ RUD DR0, RUD DR1, ELE DR0, ELE DR1, AIL DR0, AIL DR1, GEAR0, GEAR1, MIX0, MIX1, MIX2, FMOD0, FMOD1, FMOD2
-  * **Devo12**: \\ RUD DR0, RUD DR1, RUD DR2, ELE DR0, ELE DR1, ELE DR2, AIL DR0, AIL DR1, AIL DR2, GEAR0, GEAR1, MIX0, MIX1, MIX2, FMOD0, FMOD1, FMOD2, HOLD0, HOLD1, TRN0, TRN1+  * **Devo12**:
 +     * **Stock**: \\ RUD DR0, RUD DR1, RUD DR2, ELE DR0, ELE DR1, ELE DR2, AIL DR0, AIL DR1, AIL DR2, GEAR0, GEAR1, MIX0, MIX1, MIX2, FMOD0, FMOD1, FMOD2, HOLD0, HOLD1, TRN0, TRN1
-  * **Devo F7**: \\ AIL_DR0, AIL_DR1, GEAR0, GEAR1, MIX0, MIX1, MIX2, FMOD0, FMOD1, FMOD2+  * **Devo F7**:
 +     * **Stock**: \\ AIL_DR0, AIL_DR1, GEAR0, GEAR1, MIX0, MIX1, MIX2, FMOD0, FMOD1, FMOD2
 +  * **Devo F4**:
 +     * **Stock**: \\ The Devo F4 has no switches at all.
 ==== Virtual switches ==== ==== Virtual switches ====
-The lack of switches on the Devo7e and Devo6 can be dealt with by using the *Trim as Virtual Switch*. See the manual for details on how to set those up. Using the throttle trim switches as a pair works well, and the buttons beside the LCD can be used as push-button switches.+The lack of switches on the Devo F4, Devo F7, Devo7e and Devo6 can be dealt with by using the *Trim as Virtual Switch*. See the manual for details on how to set those up. Using the throttle trim switches as a pair works well, and the buttons beside the LCD can be used as push-button switches.
 ==== Other inputs ==== ==== Other inputs ====
 In addition, the Devo 10, 12, and F12E have extra analog inputs. The 10 has AUX4 and AUX6, the 12 has AUX2-AUX6, and the F12E has AUX4-AUX7. In addition, the Devo 10, 12, and F12E have extra analog inputs. The 10 has AUX4 and AUX6, the 12 has AUX2-AUX6, and the F12E has AUX4-AUX7.
transmiterswitches.1460734709.txt.gz (16954 views) · Last modified: 2016/04/15 08:38 by FDR
