transmitter:devo6
transmitter:devo6 [2016/05/13 16:09]
Deal57 [Hardware Information]
transmitter:devo6 [2017/01/23 00:40] (current)
FDR https
Line 22: Line 22:
 ==== Installing DeviationTx ==== ==== Installing DeviationTx ====
-Start by reading the Devo 6 [[http://​www.deviationtx.com/​user-manual/​user-manual-6-8-12|manual]].+Start by reading the Devo 6 [[https://​www.deviationtx.com/​user-manual/​user-manual-6-8-12|manual]].
Line 49: Line 49:
 The Devo 6 was found to have unpopulated headers for several switches and trim pairs, which simply require soldering and the appropriate code to enable. The Devo 6 was found to have unpopulated headers for several switches and trim pairs, which simply require soldering and the appropriate code to enable.
 This modification will add two 2-way switches labeled "SW A" and "SW B", or one 3-way switch labeled "SW A", plus two new pairs of trims. This modification will add two 2-way switches labeled "SW A" and "SW B", or one 3-way switch labeled "SW A", plus two new pairs of trims.
-  *[[http://​www.deviationtx.com/​forum/​6-general-discussions/​2102-adding-switches-to-devo-6s|Adding switches to the Devo 6S]] by RoGuE_StreaK,​ Deal57, and mwm in our forum+  *[[https://​www.deviationtx.com/​forum/​6-general-discussions/​2102-adding-switches-to-devo-6s|Adding switches to the Devo 6S]] by RoGuE_StreaK,​ Deal57, and mwm in our forum
 == Arduino to PPMin for Extra Inputs == == Arduino to PPMin for Extra Inputs ==
 The trainer port can be hijacked for an arduino to provide PPM signals from nearly any combination of switches and potentiometers. This modification effectively takes over the trainer port by mimicking a 2nd connected transmitter and injects PPM signal to the channels. Note that once you do this mod, you will not be able to connect another transmitter to the trainer port. The trainer port can be hijacked for an arduino to provide PPM signals from nearly any combination of switches and potentiometers. This modification effectively takes over the trainer port by mimicking a 2nd connected transmitter and injects PPM signal to the channels. Note that once you do this mod, you will not be able to connect another transmitter to the trainer port.
   *[[http://​www.rcgroups.com/​forums/​showthread.php?​t=2481981|Extra Potentiometer and Switch Inputs for Devo TX]] by JW57RC on rcgroups.com   *[[http://​www.rcgroups.com/​forums/​showthread.php?​t=2481981|Extra Potentiometer and Switch Inputs for Devo TX]] by JW57RC on rcgroups.com
-  *[[http://​www.deviationtx.com/​forum/​7-development/​4442-extra-inputs-for-devo-tx-s?​limitstart=0|Extra inputs for Devo Tx's]] by mwm in our forum+  *[[https://​www.deviationtx.com/​forum/​7-development/​4442-extra-inputs-for-devo-tx-s?​limitstart=0|Extra inputs for Devo Tx's]] by mwm in our forum
 == Swivel Dipole Antenna Mod == == Swivel Dipole Antenna Mod ==
Line 65: Line 65:
 Swap out to a higher capacity LiPo battery. Search around as there are now few manufacturers that make a LiPo specifically for the Devo 7E/6. Swap out to a higher capacity LiPo battery. Search around as there are now few manufacturers that make a LiPo specifically for the Devo 7E/6.
   *[[http://​www.rcgroups.com/​forums/​showpost.php?​p=28700856&​postcount=3|Turnigy nano-tech in Devo 7E]] by Fyathyrio on rcgroups.com   *[[http://​www.rcgroups.com/​forums/​showpost.php?​p=28700856&​postcount=3|Turnigy nano-tech in Devo 7E]] by Fyathyrio on rcgroups.com
-  *[[http://​www.deviationtx.com/​forum/​how-to/​1455-battery-mod-devo7e|Battery Mod Devo 7E]] by Usjak in our forum+  *[[https://​www.deviationtx.com/​forum/​how-to/​1455-battery-mod-devo7e|Battery Mod Devo 7E]] by Usjak in our forum
 == USB Charge Mod == == USB Charge Mod ==
transmitter/devo6.1463180966.txt.gz (4330 views) · Last modified: 2016/05/13 16:09 by Deal57
