Return to stock firmware problem
29 Nov 2012 01:00 - 29 Nov 2012 01:31 #3384 by Muskoka
Return to stock firmware problem was created by Muskoka
Hi guys, had a look at the software, it's not for me. Went to Walkera, downloaded the firmware and library for my Devo 10, "upgraded" both through dfuse, now my menus are all messed up. How do I get this back to stock.
There is a picture of what I see at the bottom of this link at RcGroups.
www.rcgroups.com/forums/showthread.php?t=1611471&page=123
Edit: Deviation is up and running again, how do I get back to stock without corrupt menus.
Last edit: 29 Nov 2012 01:31 by Muskoka.
29 Nov 2012 01:57 #3386 by PhracturedBlue
Replied by PhracturedBlue on topic Return to stock firmware problem
That appears that your language is set incorrectly (and that the fonts are missing). Most likely something wrong with installing the 'lib' part of the firmware, though I'm not sure what
29 Nov 2012 02:06 - 29 Nov 2012 02:08 #3388 by Muskoka
Replied by Muskoka on topic Return to stock firmware problem
I've tried twice to "upgrade" the library and each time the menus are messed up. The firmware loads fine. When I turn the radio on it looks like it did stock, it's only when I access the menus that things are a mess. I'm back to Deviation now, but would be nice to get back to stock. I'm not totally illiterate with this stuff so fire away with any ideas / suggestions. Thanks for your time.
Glen
Last edit: 29 Nov 2012 02:08 by Muskoka.
29 Nov 2012 02:43 - 29 Nov 2012 03:22 #3391 by Muskoka
Got it to work. Re-downloaded the software from FDR's site and it loaded fine. I downloaded the files from Walkera twice so it appears the file is bad, or the download was corrupt twice. Anyways thanks for your help and your good files FDR.
Glen
Last edit: 29 Nov 2012 03:22 by Muskoka.
29 Nov 2012 03:20 #3394 by PhracturedBlue
glad to hear you were successful.
29 Nov 2012 05:26 - 29 Nov 2012 14:15 #3396 by FDR
Replied by FDR on topic Return to stock firmware problem
Muskoka wrote: Got it to work. Re-downloaded the software from FDR's site and it loaded fine. I downloaded the files from Walkera twice so it appears the file is bad, or the download was corrupt twice. Anyways thanks for your help and your good files FDR.
Glen
You are welcome, but I don't store the files, those links point to the Walkera site too...
Last edit: 29 Nov 2012 14:15 by FDR. Reason: typo
29 Nov 2012 14:14 #3412 by Muskoka
Well, it must have been corrupt downloads then. I tried multiple times with multiple downloads and the only time it worked was when I used the download link from your site....odd.
Glen
29 Nov 2012 21:05 #3437 by NewJocker
Replied by NewJocker on topic Return to stock firmware problem
Same for me with devo 8s.
Solved with upgrad lib.
Time to create page: 0.079 seconds
