Cant install latest version
- togy
06 Jan 2013 14:02 #4738
by togy
Cant install latest version was created by togy
When i tried installing the latest version I just get a black screen and a clicking sound when i start the transmitter. Ive installed the dfu file using the walkera tool and installed the latest library.
It works fine to go back to walkera devention firmware but i cant get the deviation to work again! Please help, i love deviation!!
Thanks,
Tom
Thanks,
Tom
- Hexperience
06 Jan 2013 14:30 #4739
by Hexperience
Replied by Hexperience on topic Cant install latest version
Which TX and version? Did you compile it yourself or download one? When you say installed the library, do you mean formatted the flash drive and copied over the files from the FS zip file?
- togy
06 Jan 2013 22:41 #4758
by togy
Replied by togy on topic Cant install latest version
Devo8s. Downloaded from this site.Formated the drive and extracted the library to it. However, the problem disapeared when I only copied the with actual content to the drive and not the complete "filesystem>devo8" folder. Weird since I did not have to do that with my previous version (1.1.2).
- RugWarrior
06 Jan 2013 22:48 - 06 Jan 2013 22:49 #4762
by RugWarrior
Replied by RugWarrior on topic Cant install latest version
Hi togy,
inside the zip is the following folder structure:
filesystem -> devo8 -> many folders...
Change into the folder devo8 where the tx.ini is located and copy everything from there to the root of your Devo drive.
Than it should work... and do not forget to "eject" the drive if you use Windows
Maybe it would be an idea for the future to "optimize" the filesystem zip file a bit to just contain the "right" files without the upper folders...
But great that it looks like it is working for you now
Last edit: 06 Jan 2013 22:49 by RugWarrior.
- clearprop88
07 Jan 2013 01:05 #4764
by clearprop88
Replied by clearprop88 on topic Cant install latest version
I have a Devo 6.
I tried updating to 2.1.0 but there is no FS file for the Devo 6.
Will an earlier version of the FS file work?
I had to go back to version 1.1.2.
That's the earliest version with an FS file.
07 Jan 2013 03:16 - 07 Jan 2013 03:16 #4768
Replied by vlad_vy on topic Cant install latest version
You can use filesystem for Devo 8, actually Devo 6/8.
Last edit: 07 Jan 2013 03:16 by vlad_vy.
- togy
07 Jan 2013 09:16 #4780
by togy
Thank you!
What is the "root"?
What is the "root"?
07 Jan 2013 09:27 #4783
Replied by rbe2012 on topic Cant install latest version
"root" means the highest point of the removeable drive where your devo is mapped; e.g. E:, then "root" is E:\ and the dirs/files are called E:\tx.ini, E:\models, E:\modelico and so on.
- clearprop88
09 Jan 2013 16:07 #4860
by clearprop88
I just got my new Devo 8 up and running with Deviation v2.1.0.
I have my models in my Devo 6 which were generated using v1.1.2.
I transferred those models from my Devo 6 to my new Devo 8.
Is it OK to do that, or should I start all over, and build the models from scratch in my Devo 8?
Time to create page: 0.077 seconds
- Cant install latest version
