Can not install V 2.1.1 on Devo 6.
31 Jan 2013 23:55 #5869 by LeGriffon
Can not install V 2.1.1 on Devo 6. was created by LeGriffon
I currently fly with V 1.1.2 on my Devo 6 and I try to install new version 2.1.1 but it do not work. After loading TX seems to reboot in dead loop. Any suggestion ?
Thanks in advance for help, and for this very nice software.
Rgds
Pascal.
01 Feb 2013 01:33 - 01 Feb 2013 01:35 #5870 by PhracturedBlue
Replied by PhracturedBlue on topic Can not install V 2.1.1 on Devo 6.
1) Hold ENT on power up and make sure USB mode works. If not, redownload and re 'upgrade' the firmware
2) if usb mode works, make sure to copy the 2.1.0 devo8 filesystem (preserve your models though)
I think others have also mentioned issues for the devo6. I don't have one so I can't verify it works, but there should be no difference between the 2.1.0 and 2.1.1 release.
If neither 1 or 2 works, try 2.1.0 and see if it works for you.
Last edit: 01 Feb 2013 01:35 by PhracturedBlue.
01 Feb 2013 18:54 #5889 by LeGriffon
Replied by LeGriffon on topic Can not install V 2.1.1 on Devo 6.
I got it... it is tricky, but you have to press and hold the enter key to enter and stay in USB mode (USB symbol is display on TX screen), and then after copy the new FS files it works.
Next step telemetry. Telemetry monitor menu says Telemetry is not supported, when I understood that one of the goods news of V2.1.1 is telemetry... Is there something to do to able it ? (of course my Devo6 is S one and got telemetry module).
Thanks for help.
Rgds
Pascal.
01 Feb 2013 19:56 - 02 Feb 2013 09:58 #5890 by domcars0
Replied by domcars0 on topic Can not install V 2.1.1 on Devo 6.
Which protocol have you configured for your model?
Last edit: 02 Feb 2013 09:58 by domcars0.
01 Feb 2013 23:29 #5896 by LeGriffon
Thanks,
Telemetry depends on models... If I use a devo RX601 model I can open the menu now. Thanks for help.
Rgds
Pascal.
02 Feb 2013 09:59 #5904 by domcars0
LeGriffon wrote: Thanks,
Welcome,
No, I think telemetry depends on protocol ...
02 Feb 2013 10:39 #5905 by FDR
Replied by FDR on topic Can not install V 2.1.1 on Devo 6.
...but can be enabled/disabled by model.
02 Feb 2013 14:38 #5906 by domcars0
FDR wrote: ...but can be enabled/disabled by model.
right ;)
Time to create page: 0.300 seconds
