2 More Switches on DEVO 8
03 Mar 2013 21:23 #7301 by clearprop88
2 More Switches on DEVO 8 was created by clearprop88
There are two switches at the top of my Devo 8 labeled + -
I couldn't find these switches in the switch selection list.
Are they labeled as something else, or just not assigned?
The same switches on my 2801 Pro are lableled Flap/Hov P, and AUX 3/Hov T.
03 Mar 2013 21:42 #7302 by domcars0
Replied by domcars0 on topic 2 More Switches on DEVO 8
They are not switches,they are trims ... In deViation you will find them
as TRIM_L+, TRIM_L-, TRIM_R+ and TRIM_R-,
03 Mar 2013 22:01 #7304 by clearprop88
Replied by clearprop88 on topic 2 More Switches on DEVO 8
I have only LV, RV, LH, RH for trims on my screen.
Are the other Trims included in the nightlies?
Anyway they actually are switches.
Could they be assigned as a switch instead of a Trim?
Just asking. It might be useful to have 2 additional switches.
03 Mar 2013 22:11 - 03 Mar 2013 22:13 #7305 by domcars0
clearprop88 wrote: I have only LV, RV, LH, RH for trims on my screen.
Those trims are in deViation since the first release I think . Take a look
at the Trims page, click on the first left button (THR for exemple) ...
You can then assign a trim (Trim+ and Trim-) to this INPUT (THR) click on < or >
and you will see TRIM_L+, TRIM_L-, TRIM_R+ and TRIM_R-
clearprop88 wrote: Anyway they actually are switches.
Yes but you have to setup this with the mixers, and choose for example an Min/Max curve.
Last edit: 03 Mar 2013 22:13 by domcars0.
04 Mar 2013 05:11 #7313 by clearprop88
Thanks for pointing that out.
I didn't know that all those switches were available, behind the scene, on the Trim page.
Deviation just keeps getting more, and more interesting.
06 May 2015 11:01 #32169 by martianplace
Replied by martianplace on topic 2 More Switches on DEVO 8
Thank-you for pointing out to me that these trims are L & R I was having trouble trying to assign them to a channel on my Quadcopter so I could adjust the trim on my FPV camera as it is not on a gimble, I had looked everywhere . :woohoo:
Time to create page: 0.041 seconds
