DEVO 10 w/ J6Pro Elev/Ail Mixed Up
12 Jun 2013 21:45 #10878 by gordonzo
DEVO 10 w/ J6Pro Elev/Ail Mixed Up was created by gordonzo
I have bound a NE 328a to my Devo 10 but the ELEV and AIL channels are mixed up.
I have been trying (unsuccessfully) to sort this out using the complex mixers. Any help would be much appreciated.
regards . . . g
Different fly for different guy.
13 Jun 2013 03:13 #10886 by gordonzo
Replied by gordonzo on topic DEVO 10 w/ J6Pro Elev/Ail Mixed Up
Although it doesn't really make sense to me, this is what I came up with to make it work:
Model menu > Model setup > Model type: Heli > Swashtype: none
Model menu > Mixer > 1-Ail > Simple > Src: !AIL (reversed?) > Curve: 1-to-1
Model menu > Mixer > 2-Elev > Simple > Src: Elev > Curve: 1-to-1
Is somebody able to explain why this works?
regards . . . g
13 Jun 2013 05:59 #10905 by sbstnp
Replied by sbstnp on topic DEVO 10 w/ J6Pro Elev/Ail Mixed Up
Yes looks like AIL needs to be reversed. Nothing wrong with it.
Reversing a channel has everything to do with how a servo is mounted on the frame. If you would mount said servo mirrored to the current position then you would re-reverse the channel.
What you experienced is very common.
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
13 Jun 2013 07:06 #10911 by gordonzo
Thanks.
What threw me off was that the src channel had to be reversed.
Mixer
1.Ail Simple
!AIL
If I reversed the AIL directly it was all out of whack. I had to go into the mixer and reverse Src: !AIL
regards . . . g
ps: Now trying to figure out how to make my throttle and expo curves to display as a graph.
Time to create page: 0.710 seconds
