RX1202
- soonglim
10 Nov 2013 09:09 #15485
by soonglim
RX1202 was created by soonglim
I just recently decided to use the RX1202 that came with my Devo 12S as I want to build a second trex 450. Unfortunately I ran into the following problem. I had setup my Devo 12S with the Devo-12-3.0.0 deviation and it's been working great for all my Walkera devo helis and Blade micros with DSM2/DSMX. But with the RX1202, the collective channel ("cyclic3") doesn't seem to be working correctly. There is no counter movement of the pitch servo when giving aileron stick input. The pitch servo moves on collective stick movement, but the other aileron and elevator servo does not move collectively. I'm using swashtype "None/1Servo".
Anyone had this issue with the RX1202 and devo 12s with the deviation software? Could this be just a bad brand new RX1202, since same/similar settings work on all my other receivers (devo and dsm2/dsmx)... only difference is the RX1202 has 12 channels instead of 7 or 8 on my other receivers.
- Hexperience
10 Nov 2013 12:16 #15488
by Hexperience
Replied by Hexperience on topic RX1202
Rbe is correct. It sounds like you have a normal flybar heli but when you select none or 1 servo for the swash type it means you have a flybarless controller.
- soonglim
10 Nov 2013 16:50 #15498
by soonglim
Replied by soonglim on topic RX1202
I actually have a flybarless. But tried selecting the other swashtypes... servos just go all over the place with the other swashtypes. Tried it with and without the flybarless unit (3gx), same behavior. But with the spektrum ar8000 it all works fine... it's dsmx and has different channel mapping though.
Rbe, would it be possible for you to post/upload your model for your rx1202 for me to try? If that doesn't work, then I must have a bad rx1202.
- soonglim
11 Nov 2013 08:15 #15512
by soonglim
I started with fresh model. Have the following channel setup (on Mixer screen):
Spot anything that might be a problem?
1-ELE Cyclic2
2-AIL Cyclic1
3-THR THR Complex
4-RUD RUD Expo&DR FMODE1 FMODE2
5-GEAR None
Ch6 Cyclic3
Ch7 MIX0 Expo&DR MIX1 MIX2
Ch8 None
Ch9 None
Ch10 None
Ch11 None
Ch12 None
CYC-AIL AIL Expo&DR FMODE1 FMODE2
CYC-ELE ELE Expo&DR FMODE1 FMODE2
CYC-COL THR Complex
Virt4 None
Virt10 NoneSpot anything that might be a problem?
11 Nov 2013 09:56 #15517
Replied by rbe2012 on topic RX1202
For me it's still unclear if you have only the rx1202 or additionally your fbl system 3gx installed and tested when you see the problems.
What does the manual of the fbl unit tell you about mixing? Does the unit do that? Or must it be calculated in the transmitter? If it is done twice it can have unpredictable result, even the one you described.
I actually can't send you my config, maybe later. But I have a flybar heli with mixing in the transmitter so it might not be of any use for your config.
- soonglim
11 Nov 2013 10:59 #15520
by soonglim
I've tested with both the 3gx connected and without, i.e., one case with the servos connected to 3gx, and one case where the servos are directly connected to the rx1202. The results are the same, the cyclic mix for collective input is not working for the rx1202. Doing same experiment with ar8000 (again with one case where servos are connected to 3gx, and another case where servos are connected to ar8000), both cases works as expected.
It seems the rx1202 doesn't do any collective mixing, while other receivers do. I even tried to copy my tx setting for my walkera v120d02s (since both are devo protocol), then bind with the rx1202. Again, what worked on the v120d02s receiver did not work for the rx1202 - the collective mix is not correct for the rx1202.
Is using ch6 for Cyclic3 and CYC-COL virtual channel is Cyclic3, correct for the rx1202? And for CYC-COL, using THR as source is also correct? Are there different modes for the rx1202 where it doesn't do mixing? But if the rx1202 doesn't do mixing, then the tx settings I have on the devo 12s should be doing it, right?
11 Nov 2013 11:14 - 11 Nov 2013 11:14 #15521
No, of course it doesn't do CPPM. Neither Walkera bare receiver does...
The one in the V120D02 has an inbuilt FBL controller too, so it does.
Could you post your model config file for checking if there is something wrong?
Replied by FDR on topic RX1202
soonglim wrote: It seems the rx1202 doesn't do any collective mixing, while other receivers do.
Last edit: 11 Nov 2013 11:14 by FDR.
- soonglim
12 Nov 2013 05:29 #15536
by soonglim
From all the feedback and suggestions, I went back and started from scratch and reviewed my mixes and swashtypes, and as I tried the different swashtypes, now noticed a pattern - the Aileron and Elevator cyclics are swapped for "None/1Servo" and "120" swashtypes, different from the other swashtypes and also different from other devo receivers I have. Thus swapping the wire connections for Aileron and Elevator servos on the rx1202 works - or swap the cyclic mapping on the mixer for Aileron and Elevator also works.
I now have the model settings working perfectly with the rx1202 receiver for my trex 450. Using 3gx fbl controller also now works with it. (Also tried my microbeast fbl controller and it's perfect).
Here's my working mappings using "120" swashtype, on the mixer screen:
Attached is my model setting for reference if anyone else ran into same as I did. Thanks for everyone's replies, it helped me a lot to get to a working solution.
1-ELE Cyclic1
!2-AIL Cyclic2
3-THR THR Complex
5-GEAR None
Ch6 Cyclic3
Ch8 None
Ch12 None
CYC-COL THR Complex
Virt4 None
Virt10 NoneAttached is my model setting for reference if anyone else ran into same as I did. Thanks for everyone's replies, it helped me a lot to get to a working solution.
Time to create page: 0.178 seconds
