devo 7e not working
- crave_07
13 Nov 2013 15:26 #15551
by crave_07
devo 7e not working was created by crave_07
hello everybody, i have a problem of my devo 7e it's not working at all, when i push the power button it just click but there's nothing on the screen, what should i do? i have new battery on it. please help. thanks
13 Nov 2013 19:47 #15554
Replied by rbe2012 on topic devo 7e not working
Did it work ever before? Which firmware is installed - stock Walkera or Deviation? If second: which version?
- crave_07
13 Nov 2013 20:15 #15556
by crave_07
Replied by crave_07 on topic devo 7e not working
yes it's working before for the last 20 days then died when i switch on i can see a very dim backlight on the screen like shadow of it, i can hear also the click sound when switch on, i believe it's deviation already 3.0, hope you could help, TY
- SadSack
13 Nov 2013 20:24 #15557
by SadSack
Replied by SadSack on topic devo 7e not working
Just to find out little more could you try connecting usb lead then power Tx while hold 'Ent' key, so can see if deviation is running it should show Flash drive.
- crave_07
13 Nov 2013 20:33 #15558
by crave_07
just right now sir i try it and nothing happen i can't see either the icon in my computer as will as the icon in the devo 7e tx nothing. help please
- crave_07
13 Nov 2013 20:36 #15559
by crave_07
the backlight of the screen i can see a dim light
14 Nov 2013 03:22 #15563
Replied by vlad_vy on topic devo 7e not working
If you press 'EXT' button, power on Tx and see nothing at Tx screen, then it's the hardware problem.
- crave_07
14 Nov 2013 13:31 #15569
by crave_07
sir vlad_vy if the hardware problem, what should i do, do you any procedure to do?
- SadSack
14 Nov 2013 13:55 - 14 Nov 2013 13:56 #15570
by SadSack
That's unfortunate.
Lets start with detailed picture of the internals. And hope you have a multi meter.
Oh did you use lipos to power Tx and 2 or 3s if so?
Last edit: 14 Nov 2013 13:56 by SadSack.
- crave_07
14 Nov 2013 15:49 #15577
by crave_07
i use 4 AA rechargeable batteries energize 6.40v and i try normal 4 AA energizer that's new and i can hear the click and very dim backlight on the TX
- crave_07
22 Nov 2013 15:59 #15740
by crave_07
thank you guys i'm working on it
Time to create page: 0.299 seconds
- devo 7e not working
