- Completely disable Trims - can it be done?
- flythk
29 Nov 2013 17:50 #16062
by flythk
Completely disable Trims - can it be done? was created by flythk
I am mainly into flybarless helicopters. I never use any trim on these models, and many flybarless systems advise not to use trim in their manuals. I have read the Deviation manual, but cannot figure out if I can disable trims completely.
I want the trim switches to de disabled so I don't accidentally put trim into the model.
DOes anyone know if/how this can be accomplished?
29 Nov 2013 17:53 #16063
Replied by PhracturedBlue on topic Completely disable Trims - can it be done?
Of course. Just go to the trim page and set the source for each to 'None'
- flythk
30 Nov 2013 01:17 #16078
by flythk
Replied by flythk on topic Completely disable Trims - can it be done?
Thank you, but that does not seem to work on my D12S when using the Simple GUI for helicopters. Whenever I change the source to None in the trim menu, I hit OK and the trim settings are unchanged. I don't know if this is related to the template/Simple GUI I am using or not. I will load the latest nightly build later and see if the problem persists.
30 Nov 2013 01:58 - 30 Nov 2013 02:13 #16079
yes, it looks like this is related to using the simple mixer. I need to do some more investigation before I can know how to proceed
Never mind. I see it in the Advanced mixer too (though I thought I checked it earlier today and saw it work). Anyhow, I'll get it fixed.
Last edit: 30 Nov 2013 02:13 by PhracturedBlue.
Time to create page: 0.182 seconds
