Devo 6S won't bind with OrangeRX RX3S
- Sprocket
16 Dec 2013 21:31 #16723
by Sprocket
Devo 6S won't bind with OrangeRX RX3S was created by Sprocket
I've been trying to get my Devo 6S to bind with an OrangeRX RX3S but I can't get it to work. The TX set up to use DSM2 and fixed ID is removed.
This is what I do:
1. Plug in the bind plug
2. Power on the TX
3. Plug in the battery, RX LED blinks rapidly
4. Press bind, RX LED blinks then goes solid
5. Unplug the battery and bind plug
6. Reconnect the battery.
At this point I think everything should work but no controls are responding.
Can someone help me out?
This is what I do:
2. Power on the TX
17 Dec 2013 06:54 #16735
Replied by rbe2012 on topic Devo 6S won't bind with OrangeRX RX3S
I have successfully bound two RX3s in DSM2 mode.
The way you described is the same I went. But after reconnecting the battery you have to bind again, as far as I remember. There is no auto-binding. When you have set a new fixed ID autobind will work.
- Sprocket
17 Dec 2013 08:08 #16736
by Sprocket
Replied by Sprocket on topic Devo 6S won't bind with OrangeRX RX3S
I can't get it to work using a fixed ID either. I've tried setting one before beginning and before reconnecting the battery. I am still unable to bind.
- Sprocket
17 Dec 2013 13:45 #16738
by Sprocket
I´ve found what the problem was. It turns out I had simply plugged in the ESC connector the wrong way.
I´m sorry guys. I didn't know that the RX would do anything when the power was flipped.
17 Dec 2013 13:53 #16739
Don't worry - we all have made such errors. Be glad that the receiver did not smoke away...
- Devo 6S won't bind with OrangeRX RX3S
