Installing the EMU to create models on my PC
27 Dec 2013 21:06 #17152 by coryroyce
Hi all,
I'm relatively new to Deviation, and I have been looking though past forums, but have not found clear instructions on how to setup and install the emulator on my PC.
More specifically I'm trying to setup and run the Devo8 EMU and create new models though my PC where the editing is easier than on the actual TX, and then load these model onto my Devo8s.
Can someone refer me to a forum with the full details on setting up the Devo8 emulator?
Thank you in advanced.
27 Dec 2013 22:38 #17183 by FDR
Not a big deal: unzip the emulator exe package and the whole filesystem (starting with the filesystem directory) into the same directory and run it...
30 Dec 2013 23:52 #17534 by coryroyce
Replied by coryroyce on topic Installing the EMU to create models on my PC
Thank you for the reply.
I did as you said, but I still can't run the emulator. I would see a command screen and then it would disappear and stop running.
I have attached the a screen shot of the folder where I saved the file system and and the EMU package. Can you please let me know if I'm missing something? (This is from the nightly build a few days ago.)
Thanks again for your help.
31 Dec 2013 03:29 #17541 by yidc
The screen shot appear fine to me
Are you using the filesystem for Devo 8? :huh:
31 Dec 2013 04:40 - 31 Dec 2013 04:40 #17545 by PhracturedBlue
Replied by PhracturedBlue on topic Installing the EMU to create models on my PC
the devo emulator should have a dir structure like:
emu_devo8.xxxx.exe
*.dll
filesystem/devo8/
	media
	models
	language
you have everything flat in the top level directory which is the issue.
Last edit: 31 Dec 2013 04:40 by PhracturedBlue.
31 Dec 2013 05:42 - 31 Dec 2013 05:45 #17548 by yidc
Actually I used to get the emulator working fine w/ a flat file structure for devo7e
But I get a big USB icon on screen upon startup, hit ENTER and I can get back to normal deviationtx logo
though this may not be the case for devo8 :unsure:
Last edit: 31 Dec 2013 05:45 by yidc.
31 Dec 2013 05:53 #17549 by yidc
PhracturedBlue,
Is there indeed any document or manual for emulator? e.g. key settings
It took me much time to figure out the corresponding keyboard buttons for the first time :unsure:
and it surprised me a lot that the emu will terminate when I press "\" button
31 Dec 2013 06:08 - 31 Dec 2013 06:09 #17550 by PhracturedBlue
Yes the key-bindings are in the manual. In the upcoming release the filesystem will be packaged with the emulator making start-up as easy as unzip and click
Last edit: 31 Dec 2013 06:09 by PhracturedBlue.
31 Dec 2013 06:23 #17552 by yidc
Thank you very much!! Found the key-bindings (eventually) =P
And also successfully created toggle display in devo7e, SUPER useful!!
31 Dec 2013 16:27 #17576 by coryroyce
PhracturedBlue,
I changed the file structure like you mentioned (the FS is Devo8), and the emulator came up, but then disappeared again after about 5 seconds.
I have attached a picture of the File structure you mentioned and a screen shot of the last line of code in the command screen, before the emulator shuts down and disappears.
Please let me know if you have any other suggestions I can try.
31 Dec 2013 16:44 #17580 by PhracturedBlue
If you saw my previous post, ignore it.
Try this:
dl.dropboxusercontent.com/u/52854517/dev...8-v3.0.0-0c78016.zip
I just built and tested that it works. No need for a filesystem as it is included.
31 Dec 2013 19:23 #17595 by coryroyce
I tried running based on what you sent, and the command screen cam up and was running code, and then just stopped. No emulator ever came up.
I'm running Windows 7 on my PC, could there be any restrictive settings that do not allow it to run?
Thanks again for your help!
Time to create page: 0.121 seconds
