a7105 devo 7e protox hubsan protocol
02 Apr 2014 23:05 #22062 by anarchy
a7105 devo 7e protox hubsan protocol was created by anarchy
i installed what i assume was right the tranceiver from my v911 controler into my devo 7e i the mod the text files to account for the mod and for the amp i can bind and fly syma blade v911 walkera all no problems im still amazed love it but i canot bind my protox when i set up for this i have been using others working templates the hubsanx4 protocol and it seems to freeze the tx unit ever time i hit re init or what would be bind have i done somethining wrong and is there something i can do to fix this
10 Apr 2014 12:39 #22318 by jazzjohn
Replied by jazzjohn on topic a7105 devo 7e protox hubsan protocol
I use the slow bind which is not really slow. Turn the Proto X on first to see the flashing lights. Then place the transmitter close to it and turn it on. The Proto will be sending a signal to the transmitter. Once the signal is picked up by the transmitter the bind will be quick.
20 Apr 2014 06:38 #22593 by Chispas
Replied by Chispas on topic a7105 devo 7e protox hubsan protocol
I have the same problem with the same module installed, bind him with no problem but as with any power off the TX model Hubsan bound to rekindle stays frozen
Time to create page: 0.126 seconds
