- Getting Devo 8S to bind with AR600 receiver
- bsax
27 May 2014 22:52 #23715
by bsax
Getting Devo 8S to bind with AR600 receiver was created by bsax
I have been trying for several weeks to get my Devo 8S with Deviation technology to bind with a Spektrum AR600 receiver with DSM2 technology. Everything works but ESC. The ESC is an E-flite 30 AMP Pro Switch Mode BEC Brushless ESC installed in a Parkzone P-47 Thunderbolt. I can only get about a quarter of the power from the motor. As I throttle past a quarter the motor stops working. I have tried to reprogram the ESC with no luck. The ESC works fine with a Spektrum Tansmitter. I use the Devo 8S on all my glow fuel airplanes and it works great. I hope you can help me because I would like to switch all my planes to the Devo 8S.
bsax
bsax
28 May 2014 03:42 #23719
Replied by vlad_vy on topic Getting Devo 8S to bind with AR600 receiver
Probably you need calibrate ESC to Tx. I can't find calibration procedure for this ESC, but you can try:
1. Turn on Tx. Check that throttle channel (Ch1, and mixer) has scale 100%
2. Full throttle
3. Turn on ESC (Rx)
4. After several seconds lower throttle to minimum
2. Full throttle
3. Turn on ESC (Rx)
Time to create page: 0.078 seconds
