dial for Devo 7e for gimbal tilt
31 Mar 2015 14:10 #30547 by mikea324
dial for Devo 7e for gimbal tilt was created by mikea324
Can anyone tell me if the code in deviation for a Devo 7 E will support a dial modification for gimbal tilt for the new mini gamble coming out for the Mobius camera
31 Mar 2015 15:18 #30551 by PhracturedBlue
Replied by PhracturedBlue on topic dial for Devo 7e for gimbal tilt
adding a dial to the devo7e would be quite difficult. if you search the forums you should find other discussions about it, but I don't think anyone has succeeded. the problem is that there is no easily accessible analog input that can be used to hookup to an analog dial.
31 Mar 2015 20:12 #30573 by mwm
Replied by mwm on topic dial for Devo 7e for gimbal tilt
If you want a dial specifically, the easiest way to do it is with an external box with the dial and a PPM output to the trainer port on the 7e. Deviation can then use that as an input to any of the mixers.
If you can live with just an analog input, you can use a pair of trims switches to fake it. I covered that in the last section of my tutorial on writing model configs files.
Time to create page: 0.057 seconds
