- Power output wite deviation-devo7e-v4.0.1-92a2f2f
- Hr
16 May 2015 23:37 #32670
by Hr
Power output wite deviation-devo7e-v4.0.1-92a2f2f was created by Hr
Hi
I installed the deviation-devo7e-v4.0.1-92a2f2f
But....the power out put is 150mw in the model menu there is only one option for power out put .
Any idea
Any idea
17 May 2015 03:48 - 17 May 2015 03:49 #32680
Replied by vlad_vy on topic Power output wite deviation-devo7e-v4.0.1-92a2f2f
If you have not done diode mod, it's normal. Your Devo 7e works at max power, 7mW. With diode mod you need edit 'hardware.ini' file and uncomment line 'has_pa-cyrf6936=1'
Last edit: 17 May 2015 03:49 by vlad_vy.
- Hr
18 May 2015 21:12 #32757
by Hr
Replied by Hr on topic Power output wite deviation-devo7e-v4.0.1-92a2f2f
Ok
The line has_pa-cyrf936 =1 updated and now it is working
Thank you
Thank you
Time to create page: 0.080 seconds
