DEVO 12s
- ggriffit
22 Jun 2015 10:20 #34503
by ggriffit
DEVO 12s was created by ggriffit
Hi, I need some help please, I upgraded the firmware on my 12s to v4.0.1 and it upgraded properly, but I cannot get the config file to locate the correct files or can get the correct files under the library tab as well. It says the files unable to find data for that device. However the main issue is after upgrading the firmware I cannot get the transmitter to reboot, it keeps showing me a usb sign on the screen but no menu.
Can you help, either to reset to original setting or showing me how to come out of the DfuSe USB upgrade tool and rebooting my transmitter.
The reason I upgraded was that I cannot see on the original menu under switch reverse the controls for pitch and additional switches there is only elevator, rudder, aileron and throttle. I use both JR DSX9 and Spektrum DX8 / 10 / and DX18 which all have similar functionality.
Hope this was not a big mistake on my part.
Also any idea where I can get an English copy of the original manual, on have German..
Thank you in anticipation of your help, Gavin
22 Jun 2015 10:29 - 22 Jun 2015 10:30 #34505
Replied by vlad_vy on topic DEVO 12s
See the manual for new installation to Devo12
www.deviationtx.com/manuals/html-devo8/c...tml#new-installation
Last edit: 22 Jun 2015 10:30 by vlad_vy.
22 Jun 2015 10:34 #34507
Replied by mwm on topic DEVO 12s
In particular, you need to format the USB drive that it's presenting. You're booting into USB mode instead of the transmitter because you haven't formatted the drive and set it up appropriately.
Not sure if the standard GUI will do what you want - it's pretty primitive. The advanced GUI will certainly do what you want - and a lot more. But be prepared for it to be very, very different from what you're used to.
- ggriffit
22 Jun 2015 11:25 - 22 Jun 2015 11:26 #34510
What you trying to copy? Filesystem has size about 150 kbytes. See at manual what you need to copy.
You don't need to copy:
deviation-devo12-v4.0.1.dfu
devo12-lib.dfu
debug-devo12-v4.0.1.zip
devo12-lib.dfu
Last edit: 22 Jun 2015 11:26 by vlad_vy.
Time to create page: 0.032 seconds
