ini files
- randal flagg
- randal flagg
- TomPeer
- randal flagg
- TomPeer
11 Aug 2015 00:31 #36756
by TomPeer
Replied by TomPeer on topic ini files
Yes. You can pick a empty file, and replace that with an ini file you want to use. For example. You have an ini file named v120.ini you want to use. Go to you model file in the tx. Choose a number you want to use, for example model3.ini. rename v120.ini to model3.ini and replace the file on the transmitter.
- randal flagg
- TomPeer
11 Aug 2015 00:56 - 11 Aug 2015 00:59 #36758
by TomPeer
Here are my ini files. They are for a Devo 10. I do not know if the switches on a devo 6 are the same.
Model 8 is for WLToys V977
gear is 3ax gyro / 6 ax gyro
Fmod is 3d mode
Model 12 is for Walkera V120D02S
Fmode = 3d mode
I use Rud DR for throttle hold. I don't think the 6 has that switch, so you might want to change that.
If this does not work than please tell me what switches you have and which you want to use for what, then i can try make a ini for you.
EDIT. here it is 3 o'clock in the morning, so that will be tomorrow.
Fmod is 3d mode
Fmode = 3d mode
Last edit: 11 Aug 2015 00:59 by TomPeer.
- randal flagg
- TomPeer
- TomPeer
11 Aug 2015 01:28 - 11 Aug 2015 01:33 #36762
by TomPeer
Otherwise try this link for the V977
www.deviationtx.com/forum/protocol-devel...-v977?start=40#23217
And here for the V120:
www.deviationtx.com/forum/model-configs/...inner-settings#19451
PS for the V977 you have to install an NRF24L01 module.
Last edit: 11 Aug 2015 01:33 by TomPeer.
- randal flagg
- randal flagg
- TomPeer
11 Aug 2015 07:54 #36770
by TomPeer
Strange, i have windows 10 and right mouse works fine.
But if al the above links don't work then go to index / model config and find "walkera cp helicopters"
there are several, for beginners, for 3d and more. All made by TomZ.
good luck
good luck
Time to create page: 0.108 seconds
