Devo 8s and PPM
08 Oct 2015 23:58 #38608 by ronzer
Devo 8s and PPM was created by ronzer
Is there a receiver that will work for ppm for my Devo 8s?
09 Oct 2015 04:56 #38613 by magic_marty
Replied by magic_marty on topic Devo 8s and PPM
if you have deviation installed there is several dsm2/dsmx ppm receivers that will work..
09 Oct 2015 05:01 #38614 by ronzer
Replied by ronzer on topic Devo 8s and PPM
I have Deviation but cant find a ppm receiver.
09 Oct 2015 05:13 #38617 by ronzer
I found this Lemon Rx DSMX Compatible PPM 8-Channel , But what do I set my radio to?
09 Oct 2015 07:21 #38624 by mwm
Replied by mwm on topic Devo 8s and PPM
If you are running the stock Walkera firmware, I believe the answer is "no".
If you have installed deviation but not otherwise modded the firmware, then you can there are some OrangeRx and LemonRx DSM Rx's that will bind with it and have PPM output.
If you've added the CC2500 module, then the FrSky D-series Rx's will bind to it and have PPM options.
Similar - but generally better in every way but availability - are the serial protocols: SBUS, SRXL and Spektrum's Satellite protocol. The newer OrangeRx Rx's can be had with either PPM or SBUS. There are a few Spektrum Rx's that do SRXL. The Spektrum Satellite protocol is only generated by the DSM "satellite" or "remote" Rx's. OrangeRx, LemonRx and Spektrum all make those. I'd avoid the satellite solutions for most uses.
All of these are DSM Rx's. In deviation, got to Model Menu, Model Setup, and change the protocol to DSMX.
09 Oct 2015 08:21 - 09 Oct 2015 08:38 #38626 by Thomas.Heiss
Replied by Thomas.Heiss on topic Devo 8s and PPM
Last edit: 09 Oct 2015 08:38 by Thomas.Heiss.
09 Oct 2015 17:29 #38661 by magic_marty
I use one of the Lemon 8ch PPM on my Forza 450 Heli and it works really well with no problems thus far...
09 Oct 2015 17:54 #38663 by ronzer
Can you till me which one you have and how you set up you radio to make it work?
10 Oct 2015 18:43 #38692 by jesmail
Replied by jesmail on topic Devo 8s and PPM
The Walkera rx-703a will work with stock or Deviation firmware.
11 Oct 2015 00:01 #38697 by magic_marty
ronzer wrote: Can you till me which one you have and how you set up you radio to make it work?
This is the one i use on my Forza 450 with APM flight controller made it much easier to set up ...
www.ebay.com/itm/Lemon-Rx-MX-8-Channel-P...?hash=item2a4b3b9954
11 Oct 2015 00:20 #38698 by ronzer
Thats the one I have been looking at but I will use it with the sat.
11 Oct 2015 00:24 #38699 by magic_marty
For sure if you are going to use it on a carbon fiber frame use a Sat to improve reception...on my forza i have the rx on one side and the sat on the other ..
11 Oct 2015 00:39 #38701 by ronzer
Thanks Marty.
So I just set my radio to ppm ?
11 Oct 2015 01:42 #38702 by magic_marty
No just bind it as DSMX and the receiver takes care of the PPM output ..
11 Oct 2015 01:49 #38703 by ronzer
So just keep the radio to DSMX?
11 Oct 2015 02:16 #38705 by magic_marty
yes that is what i have mine set at...
11 Oct 2015 03:00 #38710 by ronzer
Thank You
Time to create page: 0.076 seconds
