Helicopter vs Airplane Throttle feel
- Jasenk
15 Oct 2015 01:12 #38823
by Jasenk
-Jasen
Helicopter vs Airplane Throttle feel was created by Jasenk
I've had a Devo 10 for a year now and just bought another for my father. As I was setting it up I noticed his new Devo 10 has a smooth throttle feel and mine has a detent style feel. I believe smooth is mainly for helicopter and detent is for airplanes. Any insight on this would be nice. Altimately I'd like to change mine to a smooth feel if possible. Has anyone converted theirs? Seems like the transmitter would have to have the option inside to do so.
-Jasen
- 944storm
15 Oct 2015 01:20 #38824
by 944storm
Replied by 944storm on topic Helicopter vs Airplane Throttle feel
You can set they way the throttle gimbles feel by adjusting the tension of a metal bar inside the transmitter. It has a phillips head screw and is on the throttle gimble.
I've loosened mine up for a nice smooth feel.
Good luck!
Good luck!
- Arnold
15 Oct 2015 01:57 - 15 Oct 2015 02:01 #38826
by Arnold
Replied by Arnold on topic Helicopter vs Airplane Throttle feel
In this same vein, the left (throttle) stick on my white Devo-10 rests at the bottom of the throw, while my buddy's black Devo-10 rests at the center position. Is this also something that can be changed inside the transmitter?
<Edit> I checked the book, but it doesn't say anything about this.
Last edit: 15 Oct 2015 02:01 by Arnold.
- 944storm
15 Oct 2015 02:05 #38827
by 944storm
Yes, you can make it spring back to the middle. The throttle stick has the center return spring disabled. You can re-enable by opening the transmitter and looking at the throttle gimble. You will see a screw holding a plastic tab on the right hand side up. The spring will be visibly stretched. Remove the screw and it will now return to center.
Time to create page: 0.031 seconds
- Helicopter vs Airplane Throttle feel
