Deviation 4.0.1 on Devo 7e
20 Mar 2016 21:08 #44889 by trawlins
Deviation 4.0.1 on Devo 7e was created by trawlins
I recently flashed to 4.0.1 and manually transferred Model Directory (as required with 7e). I am getting"missing or bad modules" on boot up. Hitting ext from model 1 screen brings up blank screen. Upon inspection the Model Directory only lists 27 ini files and many do not appear to properly formatted. I did not backup my old model directory, as I wanted to wipe it and start anew.
Yes I do have the NFR24L01 module installed and I altered the tx.ini as per. Still same issue
So am I missing something or are the Model Modules miss configured?
20 Mar 2016 22:23 #44892 by Nitro_123
Replied by Nitro_123 on topic Deviation 4.0.1 on Devo 7e
Try reinstalling and formatting the storage space and then copying the files over. Might help.
20 Mar 2016 22:40 #44893 by trawlins
Replied by trawlins on topic Deviation 4.0.1 on Devo 7e
Did exactly that 3 times. Try opening the zip file yourself and see if the model directory is fubared or not. I would appreciate it. There are supposed to be 30 model ins's and there are 27 and many do not have proper headers.
20 Mar 2016 23:16 #44894 by Deal57
Replied by Deal57 on topic Deviation 4.0.1 on Devo 7e
This is classic corruption of the file system. Are your batteries fully charged? I won't work on files unless I can see at least 5v (I use NIMH batteries).
When you first load 4.0.1, can you boot to the unchanged system ( don't change anything, don't coy files... Just base system) and see all 30 files?
Time to create page: 0.072 seconds
