Installing replacement CYRF in 7E - Pin question?
20 May 2016 16:15 #48875 by misherman
I have removed the stock CYRF and bought the full powered one from Ehirobo. Didn't want to try the range mod.
As seen here www.deviationtx.com/wiki/modulelist/cyrf6936#devo the Devo CYRF module I bought has 2 rows of 5 pins, with 8 labeled (7 unique with 2 grounds). Pin 3 and pin 7 are not labeled. Not sure they need to be connected to anything or just ignored? :unsure:
As seen here www.deviationtx.com/wiki/rf_module_installation/devo7e the 7E pinout for the stock 7E CYRF is a single row of 7 pins. 1,5,6 are not labeled, but multi-meter shows 1 is 3.3V and 6 is 5V (pin 5 is unknown).
The 2 pins on the new 10 pin module not accounted for on 7 pin stock 7E are CSN and Reset.
Does anyone know if pin 5 on the 7E is for CSN or Reset?
Also, should either of the pins 3 and 7 on the Devo module be connected to the 3.3V pin 1 on the 7E?
Any help or direction where to look would be great. Thanks!
20 May 2016 16:44 #48879 by silpstream
Replied by silpstream on topic Installing replacement CYRF in 7E - Pin question?
Look for "WK-DEVO-S-MOD RF Module" in our 7e wiki. You'll find the link to the tutorial you need.
21 May 2016 04:20 #48925 by misherman
Thank you! found it on hacksmods.
Time to create page: 0.027 seconds
