Devo 7e wont show up as an available device
06 Jan 2017 00:53 #57567 by westyflyer#11
Devo 7e wont show up as an available device was created by westyflyer#11
Looking for help installing deviation on my devo 7e , i have read all the instructions followed step by step! Im able to open the install tool but my tx isnt showing up in available DFU devices. Tried on win 7, even tried on Windows vista! Tx os showing linked to pc! Any and all help will be very appreciated
06 Jan 2017 01:14 #57569 by ajtank
Replied by ajtank on topic Devo 7e wont show up as an available device
Did you install the USB drivers?
www.deviationtx.com/downloads-new/category/161-dfu-usb-tool
Download the v1.1 version for Windows.
06 Jan 2017 01:18 #57570 by westyflyer#11
Replied by westyflyer#11 on topic Devo 7e wont show up as an available device
Yeah, im honestly stumped
06 Jan 2017 01:47 #57571 by ajtank
Did you insert the USB plug all the way into 7e? I have no more ideas for you, sorry.
06 Jan 2017 02:42 #57572 by Cereal_Killer
Replied by Cereal_Killer on topic Devo 7e wont show up as an available device
westyflyer#11 wrote: Tx os showing linked to pc! Any and all help will be very appreciated
OK ignore that, Devo has no clue if it's connected to USB / Dfu or not (hold ENT or Ext and power up WITH NO USB INSERTED and it'll still give you the correct icon like its CONNECTED cause it doesn't care, it's up to the computer to work right, it just goes about its day either way...
First step is to go into device manager and look for the device to be recognized when you plug it in and power it up (check in both USB and Dfu modes). You didn't mention what drivers you've installed so I'm guessing it won't be recognized...
06 Jan 2017 04:01 #57576 by westyflyer#11
Deviation usb drive was installed on both my PC's, tried both uploaders, but still wont show my tx, ive even went through both PC'S and made sure adobe, and java are up to date and working
06 Jan 2017 05:13 #57578 by Arnold
Replied by Arnold on topic Devo 7e wont show up as an available device
And you are entering Upgrade mode by starting up the Devo while holding down the "Ext" key - not the "Ent" key, correct?
06 Jan 2017 05:19 #57579 by westyflyer#11
Yeah, tx shows on display screen "program update".
06 Jan 2017 05:33 #57582 by Arnold
Ok, great!
Now, verify that you have a sound USB connection (cable or port). Start the Devo in USB mode (Ent key) and check that the device has mounted.
06 Jan 2017 06:57 #57584 by westyflyer#11
Reading and showing tx connected
06 Jan 2017 07:14 #57585 by Arnold
westyflyer#11 wrote: Reading and showing tx connected
Just so I'm clear here, are you saying that your Devo mounts as a USB device on your computer?
06 Jan 2017 13:17 #57590 by westyflyer#11
Yeah on both my windows 7, and vista
06 Jan 2017 16:23 #57594 by HappyHarry
Replied by HappyHarry on topic Devo 7e wont show up as an available device
in device manager what does the devo in programming mode show up as? also what driver has it loaded?
06 Jan 2017 22:43 #57603 by westyflyer#11
It shows up as STM DFU (WinUSB), amd uploader 0.8.0
06 Jan 2017 23:12 - 06 Jan 2017 23:17 #57604 by aMax
WinUSB is the wrong device, must be STTub30 device for DFU mode. If you cannot fix this manually on your system, please use Zadig (device changer).
Works on Win7 with Dfuse USB Upgrade Tools 2.30 or 2.31.
Last edit: 06 Jan 2017 23:17 by aMax.
07 Jan 2017 00:38 #57605 by westyflyer#11
Ok got it!! Successfuly installed!!! Thanks too everyone who helped and gave advise, I really appreciate it!
Time to create page: 0.687 seconds
