- Devo 7E won't bind after update to Deviation 5.0.0
- dpowellmeii@gmail.com
25 Oct 2017 04:48 #65245
by dpowellmeii@gmail.com
Devo 7E won't bind after update to Deviation 5.0.0 was created by dpowellmeii@gmail.com
Greetings,
I have a Devo 7e what I flashed with Deviation 4.0.1 a little while back and today I flashed it with v5.0.0 and can't get it to bind with anything. Prior to this it worked fine with my Super CP and a few DSM2 models but now, nothing. What did I do wrong? Any help would be greatly appreciated.
Thanks,
D
Thanks,
D
25 Oct 2017 05:01 #65246
Replied by vlad_vy on topic Devo 7E won't bind after update to Deviation 5.0.0
Do you renew filesystem? Especially "protocol" folder.
25 Oct 2017 13:31 - 25 Oct 2017 13:57 #65259
I did, I followed the instructions exactly like they are written in the manual.
When the issue started it would bind initially but would keep dropping the signal. Eventually, after trying a few other models, it wouldn't bind at all. My DX7 binds just fine with my eachine quad and other DSM2 aircraft I have but my Devo won't bind anymore. The other odd thing I found is that when you click bind, it only shows a 2 second countdown timer.
I re-installed the original firmware and no change, still won't bind.
What are the chances that something internally went bad? Any way to check the internal components?
Replied by dpowellmeii@gmail.com on topic Devo 7E won't bind after update to Deviation 5.0.0
vlad_vy wrote: Do you renew filesystem? Especially "protocol" folder.
Last edit: 25 Oct 2017 13:57 by dpowellmeii@gmail.com.
- aMax
26 Oct 2017 00:15 - 26 Oct 2017 00:21 #65275
by aMax
Replied by aMax on topic Devo 7E won't bind after update to Deviation 5.0.0
Clear the ID on the SuperCP rx with the delivered plug. Check the manual which connector to use. As far as I remenber the
second one from top.
Then start a bind and keep the computed ID as new fixed ID, use it with every old or new model ini for the CP
Edit: This is only necessary once, from firmware version 4 to 5.
Last edit: 26 Oct 2017 00:21 by aMax.
Time to create page: 0.099 seconds
