SIMPLE SET UP & COFIGURATION
13 Sep 2018 12:39 #70876 by rizalabd2006.ra
SIMPLE SET UP & COFIGURATION was created by rizalabd2006.ra
GOOD DAY ALL DEAR FRIENDS..
PLEASE HELP ME HOW TO SET UP AND CONFIGURATION WLTOYS V950 WITH T8SG V2+
HOW TO SET THE TROTLE HOLD AND DUAL RATE SWITCH.. TQ
REGARDS
NUBIS
14 Sep 2018 23:24 #70904 by Suter
Replied by Suter on topic SIMPLE SET UP & COFIGURATION
Hi Nubis,
What mode are you? I have an .ini which I have modified from that written by Birdbarber, if you would like to load it into your jumper and test it.
Cheers
Will
14 Sep 2018 23:35 - 14 Sep 2018 23:37 #70905 by Suter
Nubis, I would also add this is not a Simple Set Up, as you have requested in your title.
WL toys use 11 chanels and are quite difficult to copy and set up, but Birdbarber and Flyingboats on RC groups have both written the .ini files.
I initially used the WL toys 977 file, got that running very nicely and copied it into my 955 file and have been adjusting it to my liking since then.
These are some of the RC groups threads which I found useful
www.rcgroups.com/forums/showpost.php?p=36761280&postcount=1611
www.rcgroups.com/forums/showpost.php?p=36784046
www.rcgroups.com/forums/showpost.php?p=36099705&postcount=8073
Good luck
Cheers
Will
Last edit: 14 Sep 2018 23:37 by Suter. Reason: corrections
24 Sep 2018 20:36 #71024 by rizalabd2006.ra
Replied by rizalabd2006.ra on topic SIMPLE SET UP & COFIGURATION
Tqvm Friend.. It help me much.. Thank you again.. Have a Nice Day..
Regard
Nubis
Time to create page: 0.043 seconds
