jumper 8 plus vs jumper 12
07 Nov 2018 15:28 #71613 by rond
jumper 8 plus vs jumper 12 was created by rond
I have a jumper 8 plus and my son is interested in buying the jumper 12, mainly because it is less expensive. What are the differences between the two? Thanks for your help.
07 Nov 2018 16:23 - 07 Nov 2018 17:41 #71615 by goebish
Replied by goebish on topic jumper 8 plus vs jumper 12
The T8 is running Deviation with a built in 4-in-1 transceiver module while the T12 is running OpenTX with an external 4-in-1 module running MULTI.
Also, the T8SG Plus has hall sensor gimbals (better, more durable), while they are potentiometers on the T12, I think that's what explains the price.
Last edit: 07 Nov 2018 17:41 by goebish.
08 Nov 2018 01:40 #71635 by rond
Replied by rond on topic jumper 8 plus vs jumper 12
thank you, that helps a lot
11 Nov 2018 18:49 #71721 by ksaves2
Replied by ksaves2 on topic jumper 8 plus vs jumper 12
Pay more and can get a T12 with Hall effect too.
12 Nov 2018 12:07 - 12 Nov 2018 13:12 #71731 by goebish
Yes I suppose they also have the T12 with better gimbals as well.
Then that's up to you to decide if you want to use Deviation or OpenTX + Multi module.
Hint: with Deviation you only have 1 firmware to flash ;) but even as a DeviationTX contributor I've to admit I love OpenTX on my Taranis ...
Last edit: 12 Nov 2018 13:12 by goebish.
Time to create page: 0.507 seconds
