help lost models
- Maurospark
21 Feb 2019 18:47 #72957
by Maurospark
help lost models was created by Maurospark
Greetings to all, I apologize if the English is not correct but I use the google translator. I've just got a jumper t8sg plus v2. installing three new files of models I lost the three factory installed files. is it possible to reset the radio or someone could post them the original files? why were they deleted? does the jumper only support 30 models? Thanks in advance
- Fernandez
21 Feb 2019 19:35 #72958
by Fernandez
Replied by Fernandez on topic help lost models
www.deviationtx.com/downloads-new/category/13-nightly-builds
Here you can download the latest firmware you could flash ifyou want,using Walkera Defuse.
But inside each nightly download, you find also the default files and folder structure you can copy on your USB drive of the transmitter.
- Maurospark
22 Feb 2019 02:34 #72962
by Maurospark
Replied by Maurospark on topic help lost models
OK thank you very much! To copy files from the PC to the Jumper must necessarily use walkera dfuse? Maybe I lost the files because I did without?
- kungpow
22 Feb 2019 09:07 #72963
by kungpow
Replied by kungpow on topic help lost models
When you update the firmware you want to copy the model, icon and hardware files before and put them back on the radio after updating.
- Fernandez
22 Feb 2019 10:01 #72965
by Fernandez
Firmware, hex file you could flash it using Defuse flash tool, in that case you upgrade the firmware of the Tx and change features options etc.
In your case you can just acces, the USB drive of your Tx and copy the complete filestructure and or the models, icons sounds etc you like to add..
After flashing Firmware, filestructure still is in place, but it is a good habit to make hard copy of your setup and models on your pc.
Please use proper "disconnect USB device" in windows and not just unplug cable, there are chances of corrupting the drive. (and need for format and reupload all)
- Maurospark
22 Feb 2019 11:36 #72966
by Maurospark
Ok, I want to recover the original file (I think it was of the drone x68) because with that I could use the simulator, liftoff and freerider. Now, with the models installed later, the commands are all wrong and I can not calibrate them ..
Time to create page: 0.698 seconds
- help lost models
