Possible Bug in Setting Expodential
11 Sep 2012 00:32 - 11 Sep 2012 00:35 #1489 by rototophe
Possible Bug in Setting Expodential was created by rototophe
As discussed in this tread there seems to be a problem with setting up expodential on chanels that have a scale value different from 100%.
I experienced the problem loading FDR's ladybird template and thought at first it was coming from the template itself. I then experienced the exact same issue while setting up a V911 from scratch. Expo works as long as the channel is 100% throw, anything less and the curve goes null output from "-n to 0", output remains OK "from 0 to +n" with expo correctly applied .
Last edit: 11 Sep 2012 00:35 by rototophe.
11 Sep 2012 00:56 #1492 by PhracturedBlue
Replied by PhracturedBlue on topic Possible Bug in Setting Expodential
Agreed. That is definitely a bug. Must be somewhat new, this was working fine in the past.
I've added a report here:
bitbucket.org/PhracturedBlue/deviation/i...operly-when-scale-is
I'll update again once I have a fix available.
11 Sep 2012 02:43 #1496 by PhracturedBlue
I've released a new dfu (1.01) which has a fix for this. It is on the Downloads page:
deviationtx.com/download-links?task=weblink.go&id=21
11 Sep 2012 18:41 #1536 by rototophe
Replied by rototophe on topic Possible Bug in Setting Expodential
Nice! Thanks for the quick fix. :cheer:
Expo working as intended now.
Time to create page: 0.111 seconds
