compatable Tx upgrades?
20 Feb 2013 21:20 #6646 by Scream
compatable Tx upgrades? was created by Scream
Hiya!
I'd like to get some pretty, red stick ends a bit larger than the stock Devo10 ends I'm using now.
Since this forum is full of expert Walkera users, I thought for sure somebody would know which brands are compatible with our stuff. Every website shows futuba, JR or spectrum models but nothing for us! :(
Also, I tightened my sticks to better feel the distance I'm pushing them, but lately noticing a slight squeak... what's the best lube to use on the stick mechanism?
Please advise!
Cheers & Thanks,
-=S=-
Cheers!
-=S=-
  • rbe2012
  • rbe2012's Avatar
20 Feb 2013 22:03 #6648 by rbe2012
Replied by rbe2012 on topic compatable Tx upgrades?
For the diameter there are two standards, afaik: M3 and M4, what is 3mm/4mm.
Walkera/Devo uses 3mm. I don't remember if it was compatible to futaba or jr or what else, but you will find this easily.
20 Feb 2013 22:09 #6649 by Scream
Replied by Scream on topic compatable Tx upgrades?
Thanks rbe2012!
I guess I gotta place another order!
Since I got back into helicopters, my visa card is starting to look like a Dali clock! :ohmy:
Cheers!
-=S=-
Cheers!
-=S=-
20 Feb 2013 22:32 #6652 by RoGuE_StreaK
Replied by RoGuE_StreaK on topic compatable Tx upgrades?
Futaba M3 I believe. Also the same as eSky and Twister (and probably most generic TXs), if you have an old TX lying around unused.
27 Mar 2013 19:27 #8157 by Scream
Hi!
I ended up grabbing a pair of Spektrum stick ends made for Dx8 and Dx6i, as they seemed easier to come across.
They fit perfectly, thanks to your info!
I added some rubber washers between the new metal knobs and the threaded m3, then tightened up the stick ends. After recalibrating the sticks, I now have smooth end points instead of stock thud :)
Let me know if you'd like to see a pic!
Cheers,
-=S=-
Cheers!
-=S=-
  • rbe2012
  • rbe2012's Avatar
28 Mar 2013 10:42 #8186 by rbe2012
Scream wrote: Let me know if you'd like to see a pic!
My English is not good enough to self-produce an imagination of where you have placed the rubber... so a picture would be nice.
28 Mar 2013 16:43 #8202 by Scream
Hiya!
Pictures are worth a thousand words so... behold my baby! :)
...Pretend there's a blue led behind the devo10 part... that's next on the list!
Cheers!
-=S=-
Cheers!
-=S=-
  • rbe2012
  • rbe2012's Avatar
28 Mar 2013 17:13 #8204 by rbe2012
Thx.
Time to create page: 0.828 seconds
