Side project: Hacking the rx2703h-d 6 axis gyro.
- Hexperience
04 Mar 2013 10:13 #7322
by Hexperience
Side project: Hacking the rx2703h-d 6 axis gyro. was created by Hexperience
Hello everyone...
I've been really enjoying my "conversion" to Walkera. The transmitters are great quality and of course deviation really unleashes them.
I've been converting a lot of my heli's over to various Walkera RX/Gyro combos and I now have a couple 2702s, a 2618 and a 2703h-d
The 2703h-d flies great, very stable and the self leveling (although very mild) gives me confidence to try new things. (First flips and inverted on this one)
Problems though;
- No ability to reverse servos
- No ability to reverse gyro compensation direction
- Unused servo ports (channels)
- Piro compensation
- Adjustment of settings such as accelerometer vs gryo (yes there is one "balance" pot.
And of course:
- No GUI to set all this up with.
So I started to think, "how hard could it be?"
We have the ability to flash the firmware on to the RX with the update tool.
Anyone interested in helping out with this project?
Cheers
Problems though;
- Piro compensation
And of course:
Cheers
04 Mar 2013 10:32 #7324
Replied by FDR on topic Side project: Hacking the rx2703h-d 6 axis gyro.
There was a similar attempt:
www.deviationtx.com/forum/6-general-disc...-reverse-engineering
- wesa-76
22 Dec 2013 09:36 #16918
by wesa-76
Replied by wesa-76 on topic Side project: Hacking the rx2703h-d 6 axis gyro.
Can you please help me if you can. My problem is fixed ID canceling. Bind plug wont work. Is there anything to do? I try update witch include canceling fixed ID solved but it doesn`t work.
- RandMental
22 Dec 2013 10:34 - 22 Dec 2013 10:50 #16919
by RandMental
Replied by RandMental on topic Side project: Hacking the rx2703h-d 6 axis gyro.
Try all the Servo ports, one of them usually works.
Edit: also see www.deviationtx.com/forum/6-general-disc...cancel-fixedid#16900
Last edit: 22 Dec 2013 10:50 by RandMental.
- Nightshift
02 Feb 2014 23:22 #19758
by Nightshift
Replied by Nightshift on topic Side project: Hacking the rx2703h-d 6 axis gyro.
cHECK IF YOU GOT THE RIGHT BIND PLUG TO CANCEL IT, i WAS HAVING A HARD TIME ONE TIME AND I DIDN'T HAVE THE RIGHT ONE SOME WALKERA BIND PLUG GOT THE JUMPER BETWEEN THE 2 OUTSIDE ONE AND SOME OTHER THE MIDDLE ONE AND A OUTSIDE ONE! CHECK THAT OUT!
- Gyori
26 Apr 2014 12:54 #22728
by Gyori
Replied by Gyori on topic Side project: Hacking the rx2703h-d 6 axis gyro.
In nut shell: for reset the signal pin (white) needs to be pulled up to the +5V (red; via the resistor) during the boot-up. Regardless where they put the pins in the "bind plug" in china....
Time to create page: 0.067 seconds
- Side project: Hacking the rx2703h-d 6 axis gyro.
